Question about Philips GOGEAR SA6045 MP3 Player
Custom playlists I picked up an SA6045 for myself and an SA3346 for the wife. My 6045 works fine and I can create / download custom playlists using MediaMonkey just fine. When it comes to the 3346, we can create and download playlists using MediaMonkey and can see the files in the \playlists folder on the device, but when we power it on and go to Music\Playlists the 3346 returns "No playlists found". Any ideas?
  • 8,596 Answers
3346 automatically changes the playlist to alphabetical format - sorry
Posted on Mar 20, 2008
When i put video in my philips go gear of the format that it supported then it shows on screen that file not supported.i m sick off it help me
The Phillips 6045 will play WAV files. You can use a program called Any video converter. Click on the link. This will allow you to convert most any video to any supported video. Plus you can adjust the conversion screen size and bit rate to fit your player. It may take some trail and error but it has the ability to make a custom video for your player.
Jan 23, 2011 | Philips GOGEAR SA6045 MP3 Player
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
My gogear 6045 is not recognized on my mac and my windows.
All Gogear products are only compatible with Windows 2000, XP or Vista.
Sep 04, 2009 | Philips GOGEAR SA6045 MP3 Player
Creating Playlists for GoGear Aria 8gb player
If you want to make a new playlist for your 8 gig GoGear Aria, all you have to do is highlight the songs you want to add, then right click the mouse and choose create playlist. Name the new playlist then cut and paste it into "Playlist" in the music choices and there you go. No WMP needed.
Aug 18, 2009 | Philips GOGEAR SA6045 MP3 Player
Factory cd player doesn't play aftermarket burned cd's
What format are you burning them in? CDA or MP3 most Factory units will only play CDA format, just pick you up a copy of Nero and choose Aduio CD, it will convert you MP3 format to CDA and you should be able to playthem with no issue, the CDA format also works in the old portable CD players as well...
Hope this Helps,
David
If my solution was helpful please rate accordingly.
Mar 17, 2009 | 2002 Jeep Wrangler
I can not download my songs
The GoGear SA 6045 is not compatible with iTunes. As iTunes moves toward DRM-free music, there are a few GoGear models that will work with it, but the SA6045 is not one of them. iTunes format is also known as AAC format. There are no GoGear's that are compatible with DRM-protected AAC format, but a few are compatible with DRM-free AAC's. Sorry.
You will have to find songs that are in Mp3 format from a different music service (or from CD).
Feb 26, 2009 | Philips GOGEAR SA6045 MP3 Player
Playlists
The SA33xx series does not support playlist transfer. You can create a Playlist on the Go as the manual suggests, but it will not allow you to transfer your own playlists.
Oct 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Model sa3346/37
Common problem with mp3 players - get whole player replaced, or watch the YouTube videos on repairing mp3 player headphones (probably won't work) - your choice.
Aug 15, 2008 | Philips GOGEAR SA6045 MP3 Player
Custom music for GTA L.C.S.
1) Download the Codemasters utility - ftp://downloads.codemasters.com/upgrade/Codemasters_EACSetup.zip
2) Make sure you have a game save for GTA on your PSP memory disk
3) Install the Codemasters utility on your PC
4) Connect the PSP to your PC in USB mode.
5) Goto the folder PSP and then SAVEDATA - look for the name of your GTA gamesave folder. For me it was ULES00151S0
6) Now you need to create a new folder in SAVEDATA that holds the custom soundtracks. Using the name of the game save folder remove the final S0 and add CUSTOMTRACKS - create a folder using this name. So for me my GTA music folder is called ULES00151CUSTOMTRACKS. Note that is a new folder - NOT the game folder renamed. For Vice City name the folder ULES00502CUSTOMTRACKS.
7) Fire up the Codemasters utility on the PC, select mp3’s from the hard disk or a music CD, select the custom tracks folder created above and convert your music.
icon_cool.gif Once converted, goto the custom tracks folder and rename all the files from *.toc to *.gta
9) Fire up GTA, select custom soundtrack in audio options and enjoy your own music.
Apr 06, 2008 | Sony PlayStation Portable (PSP) Console
"Playlist On The Go" on a Philips 4 GB SA6045 mp3 player.
I just figured out how you clear the songs from the "playlist to go". go to playlist to go, then when it shows the songs you have added press the up button and you will see the words "clear playlist to go", press the forward button and it will ask you to clear it or cancel, select clear and it will tell you it's cleared.
Dec 15, 2007 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
259 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
