Rear Speakers dont work -Audi 2004 A6 sline Symphony II
I have a 2004 Audi A6 S line with a Symphony II head unit. The rear speakers dont make a sound (with the fade control switched to all rear-no sound).
Does anyone know what the problem could be?
  • bosborn01 Mar 04, 2008
    Thanks bsh4026! Do you know how or where I can check for this? Do I have to remove the Head Unit? Where do you think I could start?
You may have a loose wire somewhere or the wires comming from the headunit could be broke or damaged
Posted on Mar 04, 2008
  • bsh4026 Mar 04, 2008
    your best bet is to remove the headunit and check there, but if the wires are fine on it, remove the rear speakers and check the backs of them.
How to replace rear main seal on an 2006 audi a6 sline?
the first thing is to determine exactly where the oil is coming from. If it is a sump gasket at the rear main area it will be easier to do that than pulling the transmission and flywheel to do it (if it is not the main seal) Next is it gear oil - reddish or if manual smells different to engine oil. IT auto and is reddish it may be an oil cooler line or a front seal in the torque converter. I am saying that if it is a rear main seal it will be a big job so make sure before you get involved.
Aug 19, 2014 | Cars & Trucks
How come all of my speakers went out in my audi a6?
take head unit out and check for loose wires
Mar 22, 2013 | 2000 Audi A6
99 A6 Subwoofer and Amplifier
I have a similar problem on Audi A6 2.5 tdi year 2000, is just that my subwoofer is working fine, but the rear speakers have no sound and the rear satellites on the same ciruits are working just fine, I cannot explain this! I have taken apart the rear speaker and teasted with an ipod and one is working fine but the other is dead! I don t know if there is any connection, or there is a filter for the rear speakers and if one speaker is dead there will be no sound on the other speaker! but as i said on the same cables satelites are working well!
Mar 16, 2010 | 1999 Audi A6
It started with the rear speakers on my 2001 Audi A6, all of a sudden, making a very loud distorted/cracking sound. Now, rear speakers do not work at all. Any clues as to what has happened and the what is...
try connecting them to a small radio or tape player to see if they still work ?? if they appear to work ok on a small set then i would be inclined to check the colours on the speaker wires then rmove the radio and try connecting another known to be good speaker to the output on the radio and if that works ok then renew the feed wires to rear speakers because thats where your fault would lie for whatever reason like a mouse got in or seat crushed the wires or whatever
Dec 01, 2009 | 2001 Audi A6
Replacing radio in a6, rear speakers don't work
Four audio systems were offered in 1998. I found no wires matching your description for any of them.
May 21, 2017 | 1998 Audi A6
2001 Audi A4 no volume from back speakers
sounds like someone cut wires in trunk or unplugged wire. or cut along step plate maybe where you get in that is where they run to the rear.
Jan 25, 2009 | 2004 Audi A4
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
1998 Audi A4 Quattro rear speaker wiring
You can't use any of those - the large connector at the OEM speakers is because the rears are amplified. Your factory head unit puts out a line level signal to the rear speakers. There's an amplifier on the driver's side rear speaker (the box around the magnet that you can see from inside the trunk).
You need to either replace the head unit with an aftermarket one to drive your new speakers, or you need to tap into the amp connector and find the line level wires, break them out, put RCA plugs onto them, and plug them into an aftermarket amp, which you'd use to power your rear speakers. Doing it that way allows you to keep the factory head unit.
Oct 25, 2008 | 1999 Audi A4
Rear speakers
If have a VOM check for voltage at the amp. If not, a cheap trouble light (often in cheap tool bin) will tell if have voltage. this will tell if the problem is the head unit or the amp or wiring.
Occasionally the remote wire will have a fuse in line.
Jan 05, 2008 | Sony CDX-GT710 CD Player
422 people viewed this question
 Grubhead
Grubhead
