Question about Kenmore 64823 Top Freezer Refrigerator
Refridgerator not very cold
Older Kenmore about 20 yrs old, worked fine till yesterday. Freezer is perfect,fan motor in freezer runs fine,little to no frost build up in freezer. Fridge is not very cold, feel no air from freezer coming into fridge? Oval holes in top of fridge not plugged with ice? Where/how does cold air get into thr fridge?Thanks Gene
  • 3 more comments
  • chloride Mar 06, 2008
    Thanks wil try all ofthe above and hope to rsolve poblem. Thx Gene
  • Anonymous Mar 17, 2014
    10 month old Bush Upright was working perfectly until I accidenatally pulled the plug out for 30 secs only. Not freezing. Why?
    Freezer was overloaded but now empty. Ice has melted. Fan inside freezer is running but air coming out is not real cold.
  • Anonymous Mar 19, 2014
    Fridge not getting cold but freezer iced up
  • Anonymous Mar 29, 2014
    Freezer works fine but the fridge is not very cold
  • 57 Answers
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
    President:
  • 778 Answers
Hello Gene,
The panel below the oval holes at the back of your fridge covers the evaporator coils, so they may be restricting your air flow even though you don't see ice through the oval holes there may still be ice build up on the coils. Being it's 20 years old this probably happened because either the refrigerant has leaked down over the years, or the fan may have failed (either would cause the evaporator coils in the fridge to ice over).
But since your freezer is still freezing, I would clear out the fridge (shelves and all) and remove the rear cover (that covers your coils) and use a blow dryer or whatever to thaw the ice and check the fan before bothering to connect refrigerant gages and checking your pressure levels.
And to answer your question, the cold air is forced past the coils from the bottom up through the oval holes via the fan/fans I mentioned above.
Good Luck.
Freezer seems to be working fine, but the refridgerator is cool at best with the thermostat all the way down. I tried to defrost, but with no help. I think the fan in the freezer might be bad.
The only place that cools in a refrigerator is the freezer. The refridgerator side stills cold from the freezer via an air duct that runs from the freezer to the refridgerator. If your fan in the freezer compartment is not working your refridgerator side will not work. To replace the fan you will need to clean out the freezer including the shelving. Then remove the back panel all you need is a phillips screw driver. When the back is replaced the fan is at the top. It is held in by two screws that go threw rubber mounts on the fan braces. You will need to remove one ground wire and two electric wires on the motor its self. Make sure to unplug the refrigerator before starting the repair. good luck
Aug 28, 2010 | Kenmore Refrigerators
My Amana refridgerator keeps defrosting on it's own. when the water and ice work it works perfect but when they quit the refridgerator is defrosting
ck for a faulty defrost teminator ( amana fans will not work till they reset at a freezing tempt and if it does not reset the freezer gets cold but the fan does not blow the cold ofer to the fresh food area . the the defrost cycle takes over and this goes on and on . and the mild goes bad . so try a terminator . . if fan motor is bad it would also cause this prob .. mm
Aug 18, 2010 | Refrigerators
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ge refrig is 30 yrs old...operating normal until yesterday. It constantly runs. the freezerer does not freeze, the circulation fan is not running in the freezer and the lower is cool but not cold.
Good day,
The freezer fan motor going bad, would cause all the symtoms you described. Remove it, take it to an appliance parts house, where they will be glad to test it. If bad, replace.
P.S. Always replace the blade as well when replacing a GE motor.
Mar 18, 2010 | GE GTS22KBP Top Freezer Refrigerator
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 64823 Top Freezer Refrigerator Logo
395 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
