Question about Memorex MVD2042 DVD Player
"Wrong disc" memorex dvd player error
My memorex dvd player won't play any dvds anymore - it will just attempt to load and then say "wrong disc"
What should i do?
  • 393 Answers
Sounds like a build up of dust on the lens.
2 options -
Either buy a DVD lens cleaner
Note DVD LENS cleaner, NOT DVD Cleaner the latter is for the discs, not the player
or second option is to remove lid from your player (usually 5 or 6 screws) and gently swab the lens with a cotton bud or similar soft lint free product. Try not to push too hard on the lens or you may damage the mechanism.
The lens is really obvious as it faces upwards and looks like a small round clear glass bead.
Make sure its unplugged too!
Posted on Mar 02, 2010
My memorex dvd player is reading wrong disc. All of my dvds are authentic so i have no idea what the problem is.
Check ur DVD discs lables said NTSC signal format this format can play only on DVD players was bought in the US,Canada or Mexico.The PAL signal format Discs this format can only play with DVD players that bought in European,Asia,Middle East or African countries.
Feb 02, 2011 | Norcent Technologies DP313 DVD Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Which recordable dvds play on this dvd player
this brand and model should be able to play the discs you mentioned witih no problems, unless it is defective, or a error is being made when you are recording the discs. If you are recording and they ar enot playing, most likely you are not "finalizing" the discs durring the burn processs. All discs MUST BE finalized to be played on any dvd player.
Feb 08, 2010 | Teac DV-3500 DVD Player
WHY DON'T SONY RECORDABLE DVDS PLAY IN SONY DVD PLAYERS? I USE THE SAME PROGRAM TO BURN MEMOREX AND SONY DISCS, THE SAME DVD+R 120 MIN/4.7GB(OTHER THAN THE BRAND BEING DIFFERENT), AND i HAVE HAD NO PROBLEM...
all dvd recorders are very very sensitive when comes to which disc is fed to them......you say sony is the same as memorex is the speed the same 4x-16x, may i also suggest maxell, dynex and vertabram
Oct 23, 2009 | Sony SLV-D300P DVD Player/VCR
My Memorex won't play DVDs, it only shows "wrong disc."
No help i know, but my Liton is in the same condition. Except mine keeps saying Insert disc...
Have you tried using a cleaning disc in case the laser is dirty?
It didn't cure mine, but you never know...
Aug 15, 2009 | Memorex MVD2040 DVD Player
Won't play dvds. Comes up wrong disc.
check your compatability specs on the player then see what format your dvd is in/clean lenses with eye glass wipes
Jul 31, 2009 | Memorex MVD2040 DVD Player
Won't play my downloaded dvds
Sorry, you need a different DVD player. That kind won't eccept DVDs that have self-recorded stuff on it.
May 10, 2009 | Televison & Video
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick http://www.dvdflick.net/ to author your dvds and use imgburn http://www.imgburn.com/ to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Shaz
Sep 30, 2008 | Philips DVP5140 DVD Player
DVD player won't play certain movies
it could be the disc that is causing the problem try some other disc and see what it does.good luck.
Mar 23, 2007 | Memorex MVD2022 DVD Player
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Memorex MVD2042 DVD Player Logo
2,241 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
