Question about HP DesignJet 450c InkJet Printer
Drive belt I am replacing the drive belt and would appreciate any help from others who have done the same procedure (service manual etc will purchase) Keithpearce
    Problem Solver:
  • 5 Answers
It's pretty easy (1 hr max) I have the service manual posted at http://sjdtrucking.com/hpplotters/index.htm
Posted on Mar 21, 2008
Alternator how to change an alternator in a 2004
Purchase a replacement of the same make and model.
Disconnect the negative battery terminal. Disconnect the alternator taking note of the plug/wire positions.
Slacken off the belt tensioner and remove the belt, taking note of its routing.
Unbolt the old alternator and fit the new one.
Refit the belt and tensioner.
Reconnect the battery.
Job done.
Apr 09, 2018 | Cars & Trucks
Does a 2007 Golf 1.9tdi s have a timing belt or chain, and when would they need replacing?
Autodata publications show it as a timing belt
recommended timing belt change at 80.000miles
this is qualified by driving conditions , highway speeds , dirt , dust and oil leaks all of which will drastically reduce the service life of the belt
the engine is identified as an intereference engine which means valve damage if the belt breaks or the replacement is not done according to correct procedure
the labor time in an accredited service shop is listed as 3.8 hours
if you have been having the services done according to the service book it should be correct in what has been ticked
you can always verify it at a service dealer shop
as the manufacturer runs engine with both chains and belts , you can verify it is a belt if it has a plastic cover over the area of the timing belt.
if it is a chain it will be a full metal cover
Dec 11, 2015 | 2007 Volkswagen Golf
Drive belt replacement on MTD riding mower 13ah660f120
Boy are you in for fun now and I suggest go ahead and replace both belts in the variable speed system while you got it apart.
Here is the service manual that cover the 600 series.
http://service.mtdproducts.com/Training_Education/770-10578.pdf
Apr 24, 2015 | Mtd Garden
Serpentine belt replacement
The 2006 Santa Fe came with three (3) different engines, each having different serpentine belt arrangements. The 4cylinder 2.4 lit has three belts, the 2.7 has only one (1) drive belt, and the 3.5 lit has two (2). Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations and procedures, etc.
Sep 02, 2011 | 2006 Hyundai Santa Fe
Replace drive belts on a xg350l 2004
Sep 01, 2011 | Hyundai XG350 Cars & Trucks
Need to know how to replace 2 drive belts for murray riding mower, Model # 425303x92A
Murray filed bankruptcy in 2004 they were purchased by Briggs and Straton in 2005
This manual is not for your specific unit (no longer available), but it uses the same drive system, so the installation procedure and routing shown starting on page 32 will show you what you need.
If you need it here is a link that you can purchase the belts
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 02, 2011 | Garden
What is the easiest way to change the drive belt tensioner?
Without getting into a long winded process, your best bet is to purchase a vehicle specific repair manual from your local major chain auto parts store (Pep Boys, Advance, Auto Zone, O'Reilly's, etc.) which should clearly outline how to perform this procedure. Shouldn't cost more than $20 for the manual.
If all you need is the pulley, that shouldn't run over $20, but if you have to buy the entire tensioner assembly, that will run probably $45.
This isn't a difficult thing to do and you'll get a lot of satisfaction in having done the job yourself.
Jan 01, 2011 | 1991 Plymouth Grand Voyager
I have a 2004 Hyundai SanteFe.I am approaching 60,000 on it. Manual calls for: replacing spark plugs, replace coolant, maybe timing belt and a hundred other check points. Cars runs and sounds great. Do I...
Yes, time to do these things.
FYI - you can purchase a complete kit for Water pump replacement which includes the timing belt, tensioner, gaskets, etc. You can't get to the water pump without first removing these items anyway, so do it before the pump fails or worse, the timing belt breaks and grenades your interference fit engine.
Example here: Amazon com Evergreen TBK313WPT 99 05 Hyundai Sonata Santa Fe Optima 2 4L...
Plugs are a piece of cake and it's time for those as well.
Replace coolant, and while you're at it, the thermostat.
I hope this helps.
Feb 08, 2018 | 2004 Hyundai Santa Fe
Better intructions than hd service manual?
The only thing better than having an authentic H-D service manual is an authentic H-D mechanic standing beside you. I've used H-D service manuals for years and worked on many bikes that I was not totally familiar with. No mechanic in the world knows it all.
Changing the final drive belt on your dresser is a rather large undertaking. Not only do you have to pull the primary drive, the clutch, the starter, and the inner primary, you also have to remove the rear wheel and the swing arm. But, it can be done by anyone with basic mechanical skills. If you have to remove the front belt pulley, you will need some special tools as well to do the job correctly.
Oct 28, 2009 | 2005 Harley Davidson FLHTC - FLHTCI...
Change drive belt on converter
dear atv owner there is no need to remove the pulleys to replace the drive belt. you must open the large pulley by hand and drop the new belt in bottom of this pulley this will hold it open then pull the belt across to engine pulley then turn the rear wheels in clockwise direction this should force the belt on the engine pulley job done jim
Mar 29, 2009 | 1998 kawasaki KLX 300
HP DesignJet 450c InkJet Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
