Are you sure it's not turning on, and not that the screen is too light?
Try turning up the contrast. Turn on the calculator. Press and release the 2ND key. Press and hold the Up-arrow key for five seconds or so.
Does that make any difference?Are you sure it's not turning on, and not that the screen is too light?
You can't post conmments that contain an email address.
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
provided ur battery and alernator is good it sounds like ignition key cylinder is bad u have to get from the dealer bring ur vin number or title so it can be coded to ur car
This may be a dumb suggestion, but have you tried changing out the battery? I had a similar problem and changed my solenoid, cleaned all grounds and wiring connections and after all that it ended up that a cell was shorting out in the battery. Something to check out anyways. Good luck and hope this helps.
camara has been working fine till yesterday, poewer won't turn on, to take pictures, but it turns on when i moved the tab to brouse pictures, bur when I switched it back power won't work
