(It sure would be helpful to know what we're talking about. If you want a more specific answer, you will need to specify the YEAR, MAKE, and MODEL of your vehicle, and BE SPECIFIC AS TO WHAT "LIGHT BULB" YOU ARE REFERRING TO). Doesn't that just make good sense? ;)
You might check the light limiter, a.k.a. wattage limiter. Check the manuel for the location. F you dont have one you can find one on the hunterfan.com sight. Some of the fans only support low wattage lights bulbs (candelabra light bulbs) 60 watts and lower. You might have to open the light limiter to check for burn marks. If there is you need to buy a new one. And if you cant find the lights at a store you can always find them at a online store.
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it
is usually located behind the upper grille and behind an access panel,
and above the lower panel. On counter top units you will need to remove
the outer cover to get to the bulb. If that doesn't solve the problem
check the on-off switch, and control board
Main Control Board
check the light bulbs, sockets and wiring. If they are good the main
control board might be defective.
Light Bulb Socket
and a new light bulb doesn't solve the problem, the light bulb socket
might be burned out and need to be replaced.
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Open
the hood and reach down into the engine bay for the fog light assembly.
If you cannot reach the fog light assembly from the top you may need to
get underneath the truck to reach it. Remove the electrical plug
running to the fog light ballast.
Remove the bulb. Unlock the fog light bulb by turning it counterclockwise and pulling it straight out of the assembly.
Slide
a new bulb into the fog light assembly. The part number you will need
for the new bulb will be located on the ballast or base of the old bulb.
Turn the bulb clockwise to lock it into the fog light housing.
5
Reconnect the electrical connector to the bulb ballast.
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
You need to remove the front panel of the TV. If you look at the picture above, this panel is the light gray piece on the bottom of the tv. It is attached with plactic connectors. Just poo it off and then you will see a metal panel with some screws. remove the panel and then you will see the light buld casing. Pull it out and replace it with the new light bulb casing. If you did not purchase a new light bulb casing and bought just the bulb, you will need to take the casing apart and replace the bulb. Make sure to mark the wires so you will know where they should be connect to the new bulb.
