Question about Sprint PCS Phone SCP-2400 by Sanyo(r) (Misty Rose) Cellular Phone
Cell phone help!
The phone does not ring, but the volume is turned up. the keys will beep when pushed, but the phone will not play any ringtones at all. What do I do? Thanks!
The phone is a Sprint PCS Sanyo.
  • brandnewbri1 Mar 04, 2008
    More info...
    I have had this phone for years, I know and love it, and never had any problems. I just had it completely stop ringing today! The model number is RL-4920.
    Again, thanks!
    Problem Solver:
  • 15 Answers
If you have a sanyo 2400 and you call someone if the phone will go on speaker then the phone speaker is fine but it does not your speaker is out, if so you will need to take it to a sprint store to have the speaker replaced, If the phone does go on speaker but the ringtone doesnt work then you will need to update software or reset the phone. By reset I mean have all the info deleted off the phone, if you want you can have a Sprint Service and Repair Tech save your numbers and do this for you.
Posted on May 03, 2008
LG flip phone won't ring, set on vibrate/ring and volume all the way up
My LG flip phone volume is all the way up. I've tried star key pound key volume keys even tried it during playing sounds and no luck. It has keypad volume but no ringtone or sound volume whatsoever. I've reset my phone and also dialed *228 but no luck yet. Any ideas?
Jan 29, 2017 | LG Cell Phones
Why does my zte savvy not ring when I have a call coming in
You can adjust the ringtone volume by pressing the Volume Up/Down Keys at the top of the left side of your phone.
This will only work if the phone is not playing media (music, etc...).
I hope this helps.
May 07, 2014 | Cell Phones
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My Jet ringtone volume is up full but still only
I too have this problem, I have reset the phone twice and that works to bring the volume back to the normal levels. However all my sounds on the phone are low, including the alarm. It wouldn't wake anything. Can somebody please explain how to return the volume without having to rest the phone. Thank you. J
Nov 17, 2009 | Samsung Jet S8000 Cell Phone
Have a new v3c phone that will only vibrate..no ring tones and cannot get it to ring
A couple of things could b set wrong. First, make sure you're volume is turned up. Flip phone open and push the top button on left to raise the volume. Second, open phone, go to menu, cursor to settings, sounds, call ringtone, single tone. Now cursor down thru the selections to pick a ringtone. Make sure the "no ring" selection is not selected. (The current selection will have a check mark on the right side.) Select the tone you want and push the center button to save it. You can then select all your other ring tones, such as message alerts the same way.
Sep 15, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Jun 09, 2009 | Samsung Cell Phones
Motorazr v8
go to Ring style>Loud or Soft details>Change Ring Volume....7 is max and o is min..
Mar 28, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Ringtone will not work
Even though I've reset the master volume, etc. the ringtones will not work, I can't play them and the phone will not ring. In tools, sounds setting, call sounds, call ringtone: help
Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
No sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Sprint PCS Phone SCP-2400 by Sanyo(r) (Misty Rose) Cellular Phone Logo
85 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
