Question about Whirlpool Duet GHW9150P Front Load Washer
Error Code I found an HF code on my machine. I have cleaned the screens. I tried to unplug it and reset the board and it didn't work. When I plug it back in, it buzzes at me and then it sounds like it is trying to pump something out of the machine. It won't let me open the door even after holding the cancel button twice.
  • 1 more comment
  • droufs Mar 13, 2008
    I will definately try that. I had the appliance person come out and they said it was a drain issue. None the less I had already had manually opened the door and it reset itself???? I could do laundry again. I even explained that to the tech and decided it must be a bad door switch??
  • vmagnan May 24, 2009
    I have the same problem. I unplugged ithe machine and when i plug it again, it's restarted the same noise. No indication, try to push every button even "end control locked" for 3 seconds. Nothing. Minutes flashing on the screen but time desn't go down. Can't cancel it. no respond.
    I unlocked manually to take my clothes off.
    Then i replugged it again and noise comes back after the door relocked automaticaly. Is it possible that the motor burned?
    Does somebody could help me?
Hi, I just brought home a Duet and have been getting the H F alarm almost every load. The control panel isn't resetting and attempting to spin out water won't start. The inside is dark and doesn't look overly filled with water. Sound familar.
What I discovered in attempting to see if there was a water level visible in the door, was that in briefly tilting the machine the panel then resets and I can start a new cycle to either rinse or spin out the current load and the door will open also.
I will be checking tomorrow with a level to see if the machine is not level and may be affecting the water level monitor.
Posted on Mar 13, 2008
  • 3,230 Answers
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
thanks
Posted on Mar 28, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
F/H is a water inlet issue, either no water is going in. or too much water has gone into machine, whithout thripping off the fill switch. . usally the doorcant be opened if water level is too high, so look through the glass. Is it full of water???? if so set to the drain spin cycle and get rid of water
Posted on Mar 04, 2008
What is code f1 on Maytag bravo washer
CCU Error code. It is basically a computer or machine control board error. If unplugging the unit for a few minutes and re-plugging does not reset the board then you are probable going to need a board.
Mar 15, 2015 | Maytag Washing Machines
Error code 8888
Try unplugging it and plugging it back in this may reset the board
Sep 13, 2014 | Washing Machines
E90 error
The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
HF Error Code on Whirlpool Washer. I am very handy. Have already checked hoses, pressure, etc. Have already unplugged for 2 minutes to reset, etc. Is there a dirty sensor, etc that I should look for?
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 24, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Possible causes for HF error. It is in the cold
Hi
Thanks for using FixYa. You are right, FH error indicates an issue with the water supply; this error occurs when after 30 seconds the control does not detect the water entering the machine and the valves turn off & error code is displayed. Check the cold water inlet valve for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Printer won't work.On the display it says:unable to clean. see trouble shooting and maintenance guide. I don't have a manual.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 26, 2009 | Brother MFC 420CN All-In-One InkJet...
Washer stuck
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 01, 2009 | Kenmore 42822 Front Load Washer
Error code HF
Or
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Whirlpool Duet GHW9150P Front Load Washer Logo
340 people viewed this question
Dan Webster
Dan Webster
Sal De
