Back to:
Tags:
La Pavoni Europiccola EPC-8 Espresso Machine
Steam and Foam
posted by Wren23 on Mar 04, 2008
Steam is coming from the safety valve - I don't see where you can tighten it - thus the pressure never builds up enough to make good foam and the green light won't go off
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 11, 2008
Helpful (85)
mirran
Rank:Guru Guru
Rating: 88%, 214 votes
You have to replace the safety valve with a new one.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Steam and Foam:
I don't want to Accept this solution
Solution #2
posted on Sep 08, 2008
Not Rated (0)
fergus832
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
You may be able to extend the life of the valve in the following way:
1. Hold the valve body with the open end of a wrench, so that it doesn't move relative to the machine body. This wrench will need to be thin, in order to get in there - I grund some material off a regular wrench, to make a "special tool" thin enough for this.
2. Put a socket on the valve and undo its housing from the top.
3. Remove the valve from its housing, clean the plug andf its seat. Then stretch the spring a bit. That will increase the pressure that holds the valve closed.
4. Reassemble, holding the valve body with the open end wrench, so that it doesn't move relative to the machine body.
Fergus.
Thank You!
Can you Help with these Coffee and Espresso Makers problems?
How do you program a Black & Decker DCM 1350 coffee...
Hi guys am looking at buying an espresso maker for our...
Call Thermos Nissan direct at 1-800-831-9242.
Using fixya.com I was able to get to the source of my...
the water keeps dripping from the back top of water tank...
Loading problems.
Repair Service
Find Coffee and Esp. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
