Question about Panasonic CT-2784VY 27" TV
Just a line on the screen?
My TV has been very sensitive, if you change the channel on the TV set and not with the remote, or shake the tv, or bump in to it in any way, sometimes just the kids running through the house sets it off, the whole picture dissapears except for a thin line of picture righ tin the middle.. Why is it doing this and how can I fix it? I used to be able to hit the TV and it would come back on and work fine, but now I can't get it to come back on... Any help would be GREAT
  • 20gar08 Sep 02, 2008
    Hi;
    I am having the same problem. Have back opened up. Where is the vertical amplifier IC / Where do I get a replacement part ?
  • 113 Answers
Your tv has a failure in the vertical circuit. Most likley since you explained that it was coming in and out you could fix it by Resoldering the connections on the vertical output IC. Replacing the vertical output IC would be your next step after this.
-Josh
Posted on Mar 04, 2008
I changed my tv from cable to an indoor antenna however I cannot get it back to set up to change it over to antenna or air. Help1
Do you mean the Curtis LED1930A 19" TV? If so, first check that the source is set to TV. Use the Source button on the TV (just below the power button) or the remote (to the right of the 0). You can use the up/down arrow keys to change lines in the Input list. Press Enter to confirm the choice if you are using the remote.
Next press Menu on the TV (the third button from the top) or remote (to the left of the 0). Use the left/right buttons to navigate to the Channel heading (the third item from the left). Use the Source key (on the TV) or press Enter on the remote to enter the menu. Use the up/down arrows to highlight Signal Type. Press Enter (or Source) and then use the left/right arrows to get Air. Press Enter to confirm the setting. Now you should be able to highlight Auto Channel Search and search for your OTA channels.
This is shown in the manual. The manual is available from Amazon here: http://s3.amazonaws.com/szmanuals/d29a408ae8fdecdc0547a724183146ef .
I hope this helps.
(The Channel menu is not accessible when the input is not set to TV.)
Mar 29, 2017 | Televison & Video
A 2 inch wide blue line just came up on the right side on our screen. It goes from top to bottom. The model number is mu42pm12x. The weird thing is that it happened right after the remote (which is...
hmmm...when the remote was bumped, as in stepped on, perhaps? or dropped? the tv itself would be unlikely to be affected in the manner in which you mention, due to this.
unplug it and let it set for 20 min, then report back here, please..
May 23, 2008 | LG Televison & Video
How do I change the sensitivity settings for the Sensor on the Sansui 42" TV.. I have a TV in the room and every time I change a channel or a setting I effect the TV in the next room.
Close the door or power down the tv in the other room to make adjustments to the main tv, I don't think there is a way to change the sensitivity of either screen you must shield your remote and its reflections from the other set I guess. have fun with that :)
Feb 27, 2015 | Sansui 19 in. LCD TV
How do I turn on my finlux tv without a remote?
There's gotta be controls somewhere on the set. Look for touch sensitive area on the front screen.
Feb 15, 2015 | Finlux 19H6030 19" LED TV 1280x720, 50 Hz,...
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
Square Black marquis takes up the screen seconds after channel changes. Can't make it go away.
Check your closed-caption settings. You will probably find the TV is set for "text" mode right now. There's usually a single button (may be marked "CC" or "Caption") on the remote control to choose the setting. It's easy to bump the button accidentally and set captions without realizing it. When set for text, the TV blacks out the area where the text would go if there was any. Turning captions to "off" will clear up the mystery.
Oct 28, 2010 | JVC AV-27530 27" TV
Model #VV2000 S # BOAA20050 CHANNEL SPEAKING SPANISH... NEED TO CHANGE TO ENGLISH QUASAR TV
Use your remote control to check the TV SAP settings. This is "second audio program" and is often used to carry the TV sound in another language. If SAP is turned on you won't notice it unless you tune to a channel where the SAP signal is present. Most remotes have a single button to control the audio settings, so it's easy to turn the feature on without knowing it by bumping the button. Turn off SAP and you should be back to English.
Mar 06, 2010 | Televison & Video
Quasar model VV2008 tv/vcr
in side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
thanks
Oct 26, 2008 | Quasar VV2009 Combo
Freak accident, won't show 75% of channels now!
I lost the manual to this set, but last night I found the Menu button on the remote. I pressed it and then clicked SetUp. There was an option for Quick SetUp of Cable/Satellite. I clicked that and it was then able to find all my cable channels again. I still do not know how we messed it up by bumping the remote -- especially when it was turned 90 degrees away from the screen -- but this has restored it. Thanks.
Jun 22, 2008 | Sharp 27K-S100 TV
My TV Says Line and Displays Just One Channel
Unfortanatly, your gonna need the original remote or a simular one to get to the channel programming mode in the menu. You can go to http://remotes.com or call 1-800-remotes and get one for your set. Im sorry i couldnt assist you more. Good Luck
Jul 12, 2006 | Panasonic PV-M2048 20 in. Combo
Panasonic CT-2784VY 27" TV Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
