Question about Frigidaire GLTF1670A Front Load Washer
Washer water level low, clothes come out dry !!
Water level seems to be low, clothes come out dry, and have to run again. Seem to be doing it every time now. I replaced the level sensor last year and still having issues, is the sensor adjustable??
Dwight in San Diego.
  • Anonymous Mar 15, 2014
    water level switch keeps going bad last one lasted 4 months and for a hundred bucks,are there any alturnatives for this part?
  • 549 Answers
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Posted on Mar 04, 2008
Clothes come out dirty in front loaded washer
Check the level sensor at the rear of the drum.
May 16, 2017 | Whirlpool Washing Machines
Found water underneath washer, clothes seem to have more water in them, washer doesn't seem to be draining properly
Can be due to clogging in the drain pump/valve which is not draining off due to the dirt accumulation. remove and clean- back flush to see if this works.
Also make sure that the level of the washer is tilted to the drain side valve as no water must remain but drain in gravity. use a spirit level to set.
Mar 21, 2011 | LG WM-1832C Front Load Washer
I know its an older dryer but maybe you can help anyway...dryer gets very hot on the inside but clothes just do not dry...I have checked all vents and made sure all is clear...any suggestions?
Check the dryer Lint Screen. Take it to the kitchen faucet and run water in it. If it holds water then you will need to wash it with some dish soap to clean the oil film off of it. It is not lettin any air through it. Also when you take out the cloths from the washer do they seem to be wring out water?? The washer may not be spinning all of the water out of the clothes.
Jan 21, 2011 | Dryers
Doesnt seem to be cleaning good. should i not be putting so many clothes in it? should I use more soap? I feel like the clothes barely get wet!
These washers use very little water. (about 2 inches in the bottom of the wash tub) The actual amount used will vary based on the volume of clothes and the type. (snythetic clothes do not absorb much water, but put in a load of cotton towels, for example, and the clothes absorb the water, causing the water level to drop, and the machine will add more water to return the level to the set point, which usually takes a several short fills, over a couple minutes)
To see that the clothes are indeed wet, just pause the machine a few minutes into the cycle. The door will unlock, and you can feel how wet they are. When the cycle completes, these machines spin so much faster (about twice as fast as most top loading machines) that the clothes feel very dry. (thus reduced drying time, and additional energy savings) Because of the lower water usage (about 12 gallons vs. about 45 for a top loader) make sure you only use 1 to 2 (max) tablespoons of HE detergent per cycle, and only 1 teaspoon of fabric softner if you use it. (don't use fabric softner on towels) Using too much addatives will cause odor issues, and possible performance issues.
Sep 03, 2009 | LG WM-1832C Front Load Washer
After the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
May 25, 2009 | Washing Machines
Water level problem with duet GHW9300WHP
The best way to check this problem is to run with no clothes in it the water fill and stop three time after the third time the water level should be high in the back tapering off to not much in the front this unit wash as a chemical wash not with a lot of water
Mar 28, 2009 | Whirlpool GHW9300 Duet Washer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Frigidaire GLTF1670A Front Load Washer Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
