Brother CS-6000 Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What should I do when error message E1 hapend
Anonymous
Level 3:
Genius:
  • Master 1,116 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1116
Questions
0
Helped
371585
Points
3174
Refer to the troubleshooting section of the manual. If you do not have a manual, you can download a free one here - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=CS6000
Turn off the power and then turn it back on.
Lower the presser foot before continuing operation.
Lee
Level 3:
  • Master 393 Answers
Lee
Master
Level 3:
Answers
393
Questions
0
Helped
106200
Points
1319
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
My Kenmore 385.19923 sewing machine is showing an E1 error. what does this mean/
All the Error codes and the fixes below.
https://www.searspartsdirect.com/diy/error-codes/sewing-machine-repair/1234596/kenmore-385-model-sewing-machine/0582
E1 Error
Zigzag motor error
Check/Repair
The E1 Error code appears when the needle bar is up and the sewing machine can't prepare the zigzag motor to start. Unplug the sewing machine and check the wiring connections on the zigzag motor and circuit board A. Replace the fuse on circuit board A if the fuse is blown. Replace circuit board A if it has a burned spot. Replace the zigzag motor if the fuse blows and circuit board A is okay. Possible parts
Fuse, circuit board A, zigzag motor
What To Do With E1 Error On Kenmore Sewing Machine?
Wayne Arthur Gallery https://www.waynearthurgallery.com > what-to-do-wit...
Sep 23, 2022 - Check the wiring connections on the zigzag motor and circuit board A. If there's a blown fuse, replace it. Disconnect the sewing machine to ...
Missing: 385.19233 ‎' Show results with: 385.19233
I have a new Kenmore sewing machine..I am receiving an ...
JustAnswer https://www.justanswer.com > Appliance Repair
Jul 11, 2011 - The E1 error code indicates that a fuse is blown on the control board. The first image below shows the fuse that corresponds to the E1 error ...
1 answer · Top answer: Hello I'm Larry and thank you for using this service. I'll be helping you with your ...
1helpful
2answers
My machine gives E1 as an error message so i don't know what to do.
Lower the pressure foot lever before continuing the operation. If the error message does not disappear, press the stitch selection key while the error message is displayed. Hope this works.
I have a CS6000 I sewing machine. I cannot get rid of the E1 message no matter what I do. Any suggestions?
The owner's manual most likely lists what the error means. If you still unable to fix it, you may need to take it for service.
https://www.sewingmachinesplus.com/brother-sewing-machine-error-code-e1.php
1helpful
2answers
Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
1helpful
2answers
Hi i keep getting the E1 error message flash up on the sewing machine, it still sews but it keeps stopping and the E1 error message comes up, what exactly is wrong with it? can you he;lp? Thanks
E1 means that your machine thinks the thread has broken.
There's nothing you can do to fix this: it has to go to an authorised Singer Service Centre for diagnosis and repair. Usually it's a faulty thread sensor.
E1-Error message is apparently the fuse were is
The E1 error message. This is due to the fuse having to be switched from the 2.5 amp to a 3.5 amp. they did not recall the machine because of the low cost $2.99.
The Fuse is Located on the Board itself.
I guess the Part Number for your model is 000182177.
You could Purchase that from :-
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=000182177&productGroupId=0020&supplierId=385&pathTaken=&filterPart=&pop=flush
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
3helpful
19606 E1 MESSAGE HELP
E1 error message is a blown fuse problem.
Check out this site it shows you how to fix it http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
