Question about RCA D61W20 61" Rear Projection Television
Can't power on easily
Hi i have a power problem. You see when i am watching my tv it runs fine but when i shut it off for an hour or longer it wont turn back on ..well it does but i have to keep hitting the power button till it turns on .if i hold the power button it blinks 5 times then blinks 1 more time then nothing..(the light on the power button not the screen )..eventually it does start up just takes a while .and i hear a ticking noise to the right side of the tv when it is trying to start up .If you just push the power button normally ..it does a series of trying to start up 3 times then doesn't do anything till you hit the button again (and you have to wait about 1 minute before it will accept the new button press).If you sit there and keep hitting the button eventually it goes through its power startup procedure, but it can take 35-55 minutes.it will finally start up the screen ..it has been so frustrating that i have simply left the tv on 24/7 and just change to a blank signal source when it's not in use. Also, when the TV finally starts up, the display is very wavy for the first 30 seconds or so before it settles down.
I don't live in the US, and the repair places I have checked (I live in Trinidad) all say that they will need to get the unit in hand, and then diagnose the problem then order the parts. This will mean that I will be without a TV for like a month (not an option).
I am an electrical engineer, so I should be able to replace any part that is causing the problem myself. However I need to know what part is causing the issue, so that I can order it. Even if I get it fixed professionally, having the part in hand before I carry it in will let me get my TV back way faster.
Any help you can offer will be greatly appreciated.
Sincerely,
James K.
  • jameskk Mar 04, 2008
    that doesn't really help. I searched the net quite a bit before giving up and paying for this service.
    Can't you find a free copy of the actual service manual (I've already found the insanely expensive ones). Or maybe find a solution from someone else who has had this same problem and got it fixed.
    I know it's not a solder problem. the reason the power button will occationally be non-responsive is that after I press power, and the tv tries 3 times to boot up, it will lock out the controls for about a minute. So all the buttons seem to be working (not a solder problem).
    Can you tell me what the blink codes for holding down the power button means. Now when I hold down the power button I get "9 blinks, a short pause and then 9 blinks again" this repeats a few times before finally turning blank again.
    that web site too was no help. I know there is a service manual available for the TV, I've seen it online for like $100. Can you access that?
  • 552 Answers
Http://www.retrevo.com/s/RCA+D61W20+service+manual?sub.x=14&sub.y=18
Start here, because you will connect with plenty of information about your tv.
Let me know if this helps.
Posted on Mar 04, 2008
    Genius:
  • 1,665 Answers
Hi have a nice day!
begin from power on switch ; have a look at it's board solders, resolder if necessary, and by the way check for any other loose connection or bad solder.
Good Luck
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 05, 2008
    Where the TV is dead and a startup problem is suspected, you would test for startup problems by injecting a signal into the base of the HOT of about 15.75 kHz.
    If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky as you know - you can blow things up if not careful (including yourself).
    A 555 timer based circuit will work fine as a signal source for this.
    WARNING: be careful if you do this.
    The HOT circuit may be line-connected and it is possible to destroy the HOT and related components if this is not done properly. I once managed to kill not only the HOT but the chopper transistor as well while working in this area.
    An expensive lesson.
    An RCA user's guide here
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Turn on tv blue light comes on.screen stays dark .nothing happens .tv would come on after 10 minutes thenit started taking longer. now not at all.
Well first of all you can tell us the Brand and the Model number of your TV? and tell how old is your TV?
Anyway you can try to reset your TV first unplug (switch off) your TV for 24 hours and then turn it again........... let us know if further you have the same problem.......
Good Luck!!
Thanks
Jan 06, 2010 | Televison & Video
Infocus 61md10 wont boot up
Unplug it from power source for an hour to two hours reconnect and turn on
Aug 16, 2009 | InFocus ScreenPlay 61" Rear Projection...
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Engine wont shut off
This sounds like a problem with the ignition switch. You should get this examined ASAP.
Jan 16, 2009 | 1999 Pontiac Grand Prix
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
When powered off, TV turns on and displays white screen, then shuts off
I ended up exchanging the TV for a new one that works fine.
Sep 12, 2008 | Televison & Video
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at jjkjjk13@hotmail.com . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
