Hello
The computer is usually clogged with dust and other debris. See if the following instructions help.
compaq nc6220 disassembly instructions
http://static.tigerdirect.com/pdf/c00622160.pdf Compaq Manual
Goto page 107 and follow the instructions to page 108.
Goto page 118 and follow the instructions to page 121.
Goto page 126 and see below:
Be sure to have a duster can with a extender tube on hand now.
On Page 126 You will remove the fan. This and the next page are the purpose
of doing this work. Follow the fan removal instructions. Check that the fan
turns freely. Take the duster and the fan and carry it outside if it is very
dusty and clogged up. Now blow the dust and accumulated debris from the fan.
Set the fan aside.
On Page 127 You will only examine the heat sink, do NOT remove any screws here!!!
The heatsink is a copper or black colored assembly with heatpipes that curve to
the right into the cooling vanes. Look into the cooling vanes that are located
in the area where the fan was mounted. If there is blockage take you duster and
the extender tube. Insert the tube into the duster and try to hold the can
upright at all times. Now spray the gas into the cooling vanes with the tube
facing the side of the computer. This will be dusty. You may want to do it
outside if careful. Otherwise, wear a dust filter mask.
To re-assemble follow the instructions in reverse order.
If there was a blockage you will see a immediate improvement.
I hope that this helps.
