Question about Baby Gear
Interchange manuals i have been searching for 5 hours to find a interchange manual for a 1997 ford escort. this manual is for cross referencing used car parts so that u have a larger selection of parts to chose from. i.e. mazda and ford have been sharing engines and transmissions and body parts for over 30 years. those parts are identical but they use different part numbers for each company. This tech support may not handle this type of problem but this is me on my knees, begging , with sad puppy dog eyes, pleading that u can at least point me in the right direction. thank u for any help in advance chad
  • 17 Answers
I'll try looking a little more, but the best I can suggest so far is to also check for an interchange manual with the Mercury Tracer, not just the Ford Escort, since the two are basically the same car.
I also suggest joining a Ford Enthusiast site, such as the one below. You can often find valuable information through other members willing to share their knowledge.
http://www.fordforum.com/
Posted on Mar 04, 2008
A FREE MANUAL BOOK OF FORD ESCORT STATION WAGON 1.6L ZETEC MOTOR ?
TYPE "MANUAL FOR FORD ESCORT STATION WAGON 1.6L ZETEC MOTOR" IN WEB SEARCH BAR IF YOU HAVE ACCESS TO INTERNET THEN LOOK FOR PDF FILE CONTAINING FORD ESCORT STATION WAGON 1.6L ZETEC MOTOR AND PRINT IT. YOU HAVE YOUR FREE MANUAL.
Jun 10, 2017 | Ford Cars & Trucks
Transmissions out of 1999 ford escort 2.0L SE SOHC and a friend has given me a manual transmission from a 1998 ford escort 2.0L SE SOHC. Will this match up without being to much of a pain in the neck
It's either a perfect match or not. And if not (because of something minor like a transaxle mount being in the wrong place) you cannot attempt to use it. So ask at a salvage yard if their interchange source shows it can be interchanged. I am guessing it will be a match, but you should find out beforehand.
Jun 08, 2017 | Ford Cars & Trucks
How to remove starter from a 1997 ford escort
This link will help. It should let you know how and what tools to use. Just copy and paste link to get started.
http://www.firstload.com/search.php?q=free 1997 ford escort repair manual pdf - Download
Feb 17, 2012 | 1997 Ford Escort
How do I change the position of my steering wheel in my 98 escort? I see nothing that would move it.
Some models have a flat lever that you pull out and down to release the column for adjustment. I think you need to find an owners manual for your popular Escort. Reading through the manual, you can learn many safety notes also. You can usually find a manual for $5. at your local salvage yard. As popular as your Escort is, you can most likely find one on line...use search engine "auto owners manuals"...compare cost before ordering. Hope this helps.
Dec 09, 2011 | 1998 Ford Escort
I am looking for a timing belt diagram for a 97 ford escort
You can get the diagram from a Chilton or Haynes repair manual, Autozone used to print these out for their customers, don't know if they still do, but they have the manuals for sure. Hope this helps.
Aug 08, 2010 | 1997 Ford Escort
What mass airflows from ford cars fit a 1998 explorer?
Cross referencing the part number - it looks like only the following with work properly: 1998 Mountaineer, 1997 - 2000 Ranger, 1997 Explorer
Mar 11, 2010 | 1998 Ford Explorer
Ford couger lower front susp/arm
I went to my local ford dealers and cross referenced part numbers for the couger and mondeo of the same year.Thankyou anyway.yours sincerely.
Jun 20, 2009 | 1999 Ford Escort
How do I check the transaxle fluid?
i have some problem for my car model ford escort 97 my switch ac is not original connection thats why a big troubole sometime fun motor is not working sometime is working and also the rpn very high if not using the AC IF I USING THE AC THE RPN IS AVERY LOW WHAT IS THE PROBLEM THANK
Oct 11, 2008 | 1997 Ford Escort
How to replace the ignition in a 97 ford escort manual, non tilt
you have to remove theplastic covering, then you will see it is about 4 bolts holding it in...
it wrapps around the column.
Oct 08, 2008 | 1997 Ford Escort
1997 escort 1.8 gti zetec
it should be a 5/8th inch (us) assuming that this is a AGSP32C plug that cross ref to a 2756 NGK plug. Let me know MRRodneyLong@gmail.com
Jun 18, 2008 | 1997 Ford Escort
Baby Gear Logo
148 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
