Question about Lexmark Optra C710 Laser Printer
Need service manual for C710.
Hi, i have a C710n optra. It just gave me a low transfer belt warning. How do i know how much life i got left, and since it is printing great is there a way to bypass it? The unit is great i just need a manual and a little bit of help.
Thanks in advance,
Matt
  • faroukhassan Oct 21, 2008
    I have a c710 with only 10942 pages and it says the transfer belt is exhausted. can you help me reset this? Thank you Farouk.
    a1faroukhassan@hotmail.com
Hi Matt, i'm not sure how you tell how much life is left, but i know that transfer belts on other laser printers usually go on working way beyond their (built in) redundancy counter. It may be possible to reset it with a service code which i will try and find for you. I have the same printer and have a number of new transfer belts for it so it might be eaisier (although not necessary) to just replace it. Maybe having put a new one in you could swap the old one back until quality gets too bad and then use the new one by which time i may have found a reset code. I can let you have a new one if it helps. Garry
Posted on Mar 19, 2008
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Lexmark Optra C710 keeps on having paper jams
Make sure the rear door is properly seated on it's hinges. Also look for any burs in the plastic guides that the paper might be catching. If you see any burs, try to smooth them out with a nail file or something.
Jan 10, 2008 | Lexmark Optra C710 Laser Printer
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
84 TRANSFER BELT EXHAUSTED
84 TRANSFER BELT EXHAUSTED indicates that the transfer belt is exhausted and must be replaced. A new transfer belt must be installed to clear this error message. For assistance, you can contact Lexmark technical support or your authorized service provider. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark Optra C710 Laser Printer
I am getting a transfer belt warning message
The transfer belt may have reached its life expectancy now. You need to replace the transfer belt soon. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 10, 2010 | Lexmark C522n Laser Printer
Consistently get a paper jam error when I go to print on my Lexmark OptraC710
sounds like you need to clean the feed rollers that feed paper into machine with clean rag and isopropyl alcohol (rubbing alcohol) and/or looking for any paper jammed in machine...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 27, 2009 | Lexmark Optra C710 Laser Printer
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
I have a 2001 hyundai elantra and the warning lights on the dashboard. I know what the oil light looks like and the airbags. What are the other two lights.
Your best bet is to go HERE and signup for a free account then Downloading your Manual - service sheets, diagrams, parts lists etc.
Hyundai is one of the best with providing their customers with free information about the vehicles!!
I have D/L the manual, and the warning lamps on the instrument cluster are...
Left to right...(starting under temp. Gauge)
WITHOUT TRIP COMPUTER
11. Traction Control Indicator Light (If installed)
12. ABS Warning Light (If installed)
13. Seat Belt Warning Light
14. Oil Pressure Warning Light
15. Charging System Warning Light
16. Parking Brake/Brake Fluid Level Warning
Light
17. Malfunction Indicator Light (MIL)
18. SRS (Airbag) Warning Light
19. Trip Odometer/Odometer
20. Trip Odometer Reset Knob
21. Low Fuel Warning Light
WITH TRIP COMPUTER
7. Front Fog Indicator Light (If installed)
8. Door Ajar Warning Light
9. Trunk Lid Open Warning Light
10. Parking Brake/Brake Fluid Level Warning
Light
11. Malfunction Indicator Light (MIL)
12. Charging System Warning Light
13. Oil Pressure Warning Light
14. SRS (Airbag) Warning Light
15. Cruise Indicator Light (If installed)
16. Seat Belt Warning Light
17. ABS Warning Light (If installed)
18. Traction Control Indicator Light (If installed)
19. Automatic Transaxle Position Indicator Light
(Auto T/A only)
22. Low Fuel Warning Light
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 21, 2009 | 2001 Hyundai Elantra
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
Lexmark Optra C710 Laser Printer Logo
229 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
