Question about Magic Mill DLX 2000 Stand Mixer
Magic mill mixer
I have a magic mill DLX assistant. It's a couple years old and the motor doesn't seem like it can handle the load anymore.
Is there something I can do? How and where can I get it serviced?
Thank you.
  • Anonymous Jun 02, 2008
    I think the motor on my mixer is burned out. It only makes a faint noise when turned on, and the bowl doesn't revolve at all.
  • 552 Answers
Majicmill.com
You may be having a problem with the motor brushes and/or bearings.
Posted on Mar 04, 2008
Where can I download manual for the Magic Mill DLX2000 ?
The manual is $10 from the manufacturer, you can order from the following link.
http://magicmillusa.com/index.php?event=product-detail&productid=51
Let me know if you need anything else.
Benjamin
Nov 04, 2010 | Magic Mill DLX 2000 Stand Mixer
My kitchen aid mixer model k45 will only operate at high speed.
Hi REINO66, I suspect you (speed) Control Plate Assembly has gone bad and needs to be replaced.
The good news is that this can be fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, feel adventurous, and your mixer is not under warranty. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Find Illus. No. 25, Control Plate Assembly, Part No. 240904-2, which is the part that needs to be replaced.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able replace your Control Plate Assembly.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 22, 2009 | Magic Mill DLX 2000 Stand Mixer
West Bend Model 41125 Suddenly Stopped under load
If the mixer does not work under load, then check motor , bearing , and control board.
If the mixer is less than one year old call manufacturer at the number listed on the owners manual.
To get parts for your mixer you can contact West Bend Appliance Parts - Bettervac 1-800-675-9491
Mar 21, 2009 | West Bend 41125 Hand/Stand Mixer
My sunbeam mixmasters turntable is not turning
Hi Jill. Your mixer's gears are made of plastic and can't really handle heavy loads such as cookie and bread doughs. Contact Sunbeam Corp. to locate a parts place near you. You'll need to replace at least the large gear that turns the turntable base, possibly the worm gear that turns the large gear too. Grease these gears when you re-install the parts. You'll have to cut a couple of cable ties to get the machine apart enough to do the work. If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 09, 2009 | Sunbeam Food Mixers
MOTOR SPINS ON MY CLASSIC STAND MIXER BUT GEARS DON'T ENGAGE
Hi all. There is damage to the transmission caused by overloading the mixer with bread or cookie dough, or by dropping a spoon or measuring cup into the mixer while it was working.
Go to mendingshed.com and download their free kitchenaid repair manual. This manual has all you, or a repair person will need to repair your model's mixer. Mending Shed also sells needed parts.
If this solution has assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid K45SS Classic Stand Mixer
Instruction manual for magic mill 2000
http://magicmillusa.com/items.php?category=26
Jun 24, 2008 | Magic Mill DLX 2000 Stand Mixer
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Noise level
its possible that you got a lemon off the factory line or they forgot to put grease into the transmission case.is there a warranty on it?if so take it back.i work for hobart which sold kitchen aid some years ago,if that mixer is less than a year old as stated,take it back or verbally speak to a kitchen aid rep. and tell them your situation.i really belive you should be able to get a replacement as long as you havent overloaded the unit or caused damage.let me know.
Jan 03, 2008 | Magic Mill DLX 2000 Stand Mixer
Magic mill DLX 2000 base sent to repair place
I just found my old invoice where I had sent my DLX to be repaired a few years ago. (I had not put in enough moisture and it walked off the (rickety) table I had set it on...)
I need to send it back again and hence my search for the info.
The gentleman I sent it to was Mordechai Roth at Magic Mill Corp in Monsey, NY (10952) This occurred back in 2000, I can't believe I saved the receipt...
Phone number is 914-368-2532 (If it's still good) I am calling tomorrow to see about sending mine in... Hope you find yours...
JT
Nov 06, 2007 | Magic Mill DLX 2000 Stand Mixer
Magic Mill DLX 2000 Stand Mixer Logo
740 people viewed this question
Top Magic Mill Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Magic Mill Food Mixer Expert? Answer questions, earn points and help others
