Question about Sony PlayStation Portable (PSP) Console
Fat shy psp !
My frien have a shy fat psp coz when u turn it on it boot to the menu and after 5 mins or less its button is not functioning... it started when the psp turn off becoz of an empty battery.... ive tried to take out d battry and use dc no luck,, but when u leave d psp lying somewhere without d battery and dc unplug for 5 hours or more.... it can turn on again after 5 mins with the dc plugged.. is it bricked??? or needed an upgrade.... im afraid that if i try to upgrade it and psp hang it will bricked 100 percent... btw its fw is 3.03 orig sony fw... plz help!! i want dat fat psp talkative>>...
  • mussicca
    mussicca Mar 17, 2008
    no.. im not flashing any... i already use d pandora battery created by C+D team but dont boot up...
  • 52 Answers
Could be a fimware error, in that case update. Its not likely a hardware issue.
Posted on Mar 04, 2008
  • 123 Answers
Where you flashing any firmware/new game etc?
Tip
Pandora's Ultimate Magic Stick 3.80M33-5
New version of UPMSv3 - universal PSP Unbricker/Downgrader/Upgrader, also known as Pandora's Ultimate Magic Stick, Now work with DC ver4 (Dark_AleX’s), for installing CFw 3.80M33-5 and creating memory stick into a “Ultimate Magic Stick” for use with “Pandora’s battery” (jigkick). Works for both PSP, Slim and/or Fat, and 1 stick for all functions for Unbricker/Downgrader tools. Also available is the “UPMS_v3.pdf Guide” to help you get started and usage.
The Ultimate Pandora’s Magic Stick is the simple solution to easily accomplish any of the following:
  • Recover any bricked PSP (Fat or Slim) and install sony firmware or CFw M33.
  • Upgrade Fat-Slims PSP to CFw 3.80M33-5, with 1.50 kernel patch-Fat Only.
  • Upgrade Fat-Slims PSP to CFw 3.71 M33-2, with 1.50 kernel patch-2 -Fat Only.
  • Update to 3.71M33-4 are installed to the ‘GAME’ folder from the XMB.
  • Downgrade Fat PSP to Fw 1.50.
  • Upgrade Fat PSP straight to CFw 3.52M33 from Extended Boot Menu then install update 3.52 M33-4 from XMB, without need to downgrade to 1.50.
  • Boot up PSP using Ultimate Loader with support for choosing which Pandora’s you reach V1, V3 or V4.
  • Boot up PSP to XMB with UPMS inserted-Fat Only.
  • Boot up to a full FW 1.50 from Memory Stick-Fat Only.
  • Use PSP Filer and other tools (If it requires 1.50, can’t for Slims).
Note: This software is free, and comes with no warranty. Despite it has been tested and it has worked, there is some risk with any PSP operation that involves flashing, so please try this at your own risk!.
Only Memory Stick "Pro Duo" are compatible. Memory Stick Duo are not supported. Read more... for installation
here.!
on Mar 06, 2008 | Sony PlayStation Portable (PSP) Console
Tip
PSP Firmware 3.71M33-2 Diagram installation.
This article will explain a diagram of PSP CFw 3.71 installation. I have provided this document as a guide to helps PSP Users get started for installation CFw 3.71M33-2 with 1.50 kernel Addon2 on both PSP, Fat and Slims. here's a simple steps to find out.
Q:How do I know what version of the firmware I have?
A:Follow this, <b>Version check :</b> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP.
Q:How do I boot into "Recovery Mode",?
A:Do a full turn off (hold power button >5sec) and hold the "R-trigger" while turn on the psp.
Q:How do I know what kernel of game folder configured.?
A:Do this via "Recovery Mode" >> "Configuration" >> "game folder homebrew (currently: 3.xx kernel)"
Q:How do I activated the plugin No-UMD of CFw M33.?
A:Do this via "Recovery Mode" >> "Configuration" >> "UMD Mode" >> Select currently : "M33 Driver - No UMD". Any 4 option umd mode you can select, we recommended to select "Sony NP9660" for most games compatibles.
Q:I getting a blank screen/BSOD when booting my PSP, after downgrading my psp with pandora's?
A:Press "Bright" button on PSP, You will get a message for telling You to press "Circle" (O). Do it, and reenter your settings. Reboot your PSP if necessary.
Source : http://e-arena.blogspot.com/2007/11/psp-firmware-371m33-2-diagram.html
Hopefully this helps..!
on Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
PSP Game error - the game could not be started - 80020148. PSP firmware is 4.01 M33-2
  1. go to ur M33 Recovery Menu.(it can be access by totally turning of your psp-holding the power button up...and then turn it on again but hold the R button.. It should appear as it turns on..)
  2. go to the configuration and press Xbutton..
  3. browse and go to UMD Mode and
  4. check if it set to <currently: M33 Driver -NO UMD>if not, just press x until it appears...
after that exit in that menu...games should play after that setting..i have encountered 8 psp's with that kind of problem...
trust me you dont want to go to a service center unless you can have a solutions on the internet...coz it will cost you 500-700php
Apr 29, 2010 | Sony PlayStation Portable (PSP) Slim...
Can Anybody Teach Me How To Install CWcheat on my psp
Open the CW cheat folder on your computer, and open the Install folder.
Copy the seplugins folder to the root directory of your PSP memory stick (ex. F:\ or E:\).
Turn of your PSP completely bu holding down the power button.
Turn it on and hold down the R button to get the Recovery Mode screen.
Go to plugins, enable all the plugins.
To open CW Cheats menu ingame, hold the SELECT button.
Apr 04, 2010 | Sony PSP-3000 Black Console
How do you fix the select button on a psp
how do you knw that the select button is not working?in most psp games the select button has no function even in the xmb menu there is no function for it.maybe youor select button is stil good.
Mar 08, 2010 | Sony PlayStation Portable (PSP) Console
I want to interchange the o and x function of my psp
Is your PSP hacked? If yes, when you boot on the PSP press simultanously L and R buttons to access Recovery Menu, and after search for the Inverse O and X. If your PSP isnt hacked yet, this is impossible.
Oct 03, 2009 | Sony PlayStation Portable (PSP) Console
My PSP Slows Down with a Flash on Screen
i know whats going on, if you are in a custom firmware, go to the recovery menu, it is when you turn on your psp while holding R, go to the CPU Speed and turn XMB speed to "Default"coz some cpu speed in psp are limited and makes it read very slow, you can even change it on the menu screen by pressing "select" button, but it will be hard coz when you press directional button to fix it it will jump to other options. so you better go to recovery though.
sorry for bad english...
Knoa
May 05, 2009 | Sony PlayStation Portable (PSP) Console
Is it a bricked?? or a fried psp???
ure logic board is fried, unless the psp went into service mode, then its bricked
Mar 04, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP Theme Help
Make a theme folder called
THEME
all caps
put it in the PSP folder, so the outcome will be
PSP/THEME
Feb 28, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
