Question about Microsoft Natural Ergonomic 4000
Zippy WK610 (USB) does not work through KVM switch
Hi, I just received my new keyboard (see subject line for details), it is the USB version. I have the following problem and could use your advise. At home I have my PC's connected through a KVM switch. Since the KVM switch has PS/2 connections for the keyboard and mouse, I use PS/2 to USB adapters for each. Unfortunately the keyboard does not seem to work through the KVM switch, but it does work when plugged into a PC directly. Any advise as to what this could be caused by is much appreciated. Thanks I've got the same problem with a Microsoft keyboard. Works plugged into the computer via USB, but not into my KVM switch through USB to PS/2 adapters. Old keyboard works fine (I'm typing this with it), but not the new one, so it isn't the connection. Thanks
  • 167 Answers
I discovered that that problem is most likely due to the power the switch draws. i have 2 kvm switches,(diferent brands) and bolth do same! company tells me this is a normal condition! i know of no work around at this time. and will post one if i discover one good day! glen.
Posted on Jul 26, 2008
When I hit any key, it throws in a bunch of asterisks
Could be either a short in the Keyboard or it is not USB adapter compatible, some mice are like this. Plug it into a computer with PS2 port and see if it still malfunctions, if it does then the keyboard has a short, if not, it is incompatible with a USB adapter. Keyboards send two codes whenever a key is pressed, one for the key itself and one to let the computer know it the Shift/Ctrl/Alt keys are being pressed.
May 16, 2017 | Zippy WK-610PS2 (wk610 (ps2)) Keyboard
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
Zippy EL-610 DRIVER
Please follow the below link to download drivers for EL-610, Since EL-610 is not available, you can download and use RF-610, an upgraded version of EL-610
http://www.zippy.com.tw/K_DOWNLOAD.asp?dl_title=&dlc_rfnbr=20&lv_rfnbr=2&data_k_download_listeinpage=0
Sep 08, 2009 | Zippy EL-610 LUMINESCENT SILVER KEYBOARD...
I have an iogear usb kva switch connected to two PCs (one desktop; one laptop). It used to work fine with a wireless keyboard (HP), but after I replaced it, it stopped allowing me to switch between PCs...
Hi ther. make sure that you connect them to the correct port. If using a wireless keyboard, connect the receiver to the keyboard port. check underneath for the keyboard icon. Make sure that the receiver is connected to that port.
May 09, 2009 | IOGear GCS632U 2-port KVM Switch
Vista driver
Hi Dave
Here is the vista drivers for you: icon_download.gif
WK-9000Vista_Driver
Good luck
Nic
DONT forget to RATE me
Apr 09, 2009 | Zippy EL-620 Keyboard
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Oct 20, 2007 | IOGear GCS632U 2-port KVM Switch
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
CS62U 2 Port USBKVM Switch not switching
Are you sure, the usb cable belonging to the keyboard is plugged in the appropriate slot?
I have a wireless keyboard/mouse, so I have only 1 usb cable going into the switch. The first time, is plugged it into the slot of the mouse, and the switch did not work, so I plugged the cable in the other slot, and now everything works properly.
May 29, 2007 | Altusen Aten CS62U-2 Port USB KVM Switch
Microsoft Natural Ergonomic 4000 Logo
91 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
