Question about Dell Dimension 2400 PC Desktop
Resolutions on monitor dell 17" flat screen
Screen resolution 640 by 480 16 bit color cannot change
  • brown55 Mar 06, 2008
    Downloaded Driver , Tried to install it but with
    no sucess. Problem still exist.
    Thanks for your help.
  • Valynntina Dec 25, 2008
    I had to wipe the OS due to a virus and now the resolution on my monitor is low. Making all my windows HUGE. I tried to change the resolution, and found I was unable. I was able to find replacement drivers, and the download SEEMED to go fine. I am still unable to change anything
  • 50 Answers
Download the video drivers from Dell.
Posted on Mar 04, 2008
  • Michael Ansnes
    Michael Ansnes Mar 10, 2008
    what was your error when installing the drivers? Also, Dell will typically have several different versions of video drivers available for any given system. Are you sure you downloaded the appropriate driver for your video card/subsystem?
I am using a compaq 1701 flat panel monitor. I installed windows Xp. The screen resolution is $4 bit color coz the driver is not installed. Looking for the driver for compaq 1701 flat panel monitor for...
The screen resolution and bit color is controlled by the video driver NOT by a driver for the monitor.
Install the correct video driver for your video card and you will be able to increase the screen resolution to over 1024 X 768 and bit color to at least 32 bits.
Jul 21, 2011 | HP Compaq 1701 17" Flat Panel LCD Monitor
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I only have low resolution and color-bit.
By "installing" the monitor. Install the proper driver for your particular monitor and it will work and allow you to adjust resolution. "Uninstalled" monitors use a default system driver that lets you see something so you can install the proper drivers.
Nov 12, 2009 | Dell E173FP 17" LCD Monitor
Large black line at the bottom of the desktop - about one inch wide. Windows opens above the frame of the desktop.
you need to change the aspect ratio or position of the screen using the menu and buttons on the monitor
Oct 30, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Dell Dimension 2400 PC Desktop Logo
185 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
