Question about Motorola Mobility RAZR V3
Motorola RAZR V3 - Backlight
When I close the flip, the backlight continues to stay on. I have tried changing the display timeout, etc. How do I fix this?
  • xr440dude Mar 31, 2008
    I changed the housing on my V3 RAZR, now the displays act like it's flipped open all the time. Also, the phone does not answer on open or hang up on close. Did I screw up a switch somewhere?
  • Anonymous Jun 07, 2008
    Same here, the keypad backlight will not turn off at all. I got an unlocked phone and I wonder if someone screwed something up. Everything else works when I open/close the flip... all relating lights and functions, asides from the keypad backlighting. :(
    Master:
  • 518 Answers
Try removing the battery for a few seconds then restart the phone. Other than that, it could be a defective switch on the phone that detects when it's closed. If it answers / hangsup when the opened or closed... the switch is good.
Geno
Posted on Mar 04, 2008
I had this same problem after dropping my phone once. Turns out there's a very tiny magnet inside the phone that trips a proximity sensor when the phone closes, in turn starting the backlight "turn off" timer. Since I do this sort of thing for a living, I cracked the phone open and glued the magnet back in place where the supporting plastic had broken allowing the magnet to move slightly.
WARNING! Do not attempt this fix unless you're very good at this sort of thing. That stinkin' magnet is super tiny and I lost mine for about an hour since I didn't see it fall out while I was taking the phone apart. Good luck!
Posted on Sep 27, 2008
I have a GSM V3 Razr I purchased unlocked. The "Display Timeout" settings are, "Off" "1 Min" and "2 min" but it doesn't matter what it is set to as the "Backlight" setting choices are "5 sec" "10 sec" and "20 sec" and these are the settings that seem to control my display. 20 sec. is the longest my display stays on. How can I change it to stay on longer?
Posted on Sep 26, 2008
I had the same issue with my razr. what worked for my phone was going to the backlight timer settings, and setting it on the '1 minute' option. it's now nice and dark. for some reason, the 'off' setting doesn't do this.
Posted on Jul 14, 2008
When not in use, the phone continues to stay illuminated, like when it's flipped open. It draws down the battery within 1 day. Any suggestions? It seems like it might be a switch not being activated when...
go through your menu options to display settings. there should be a BACKLIGHT option which should allow you to select a a lesser amount of time that the phone stays lit.
Mar 22, 2010 | Motorola Mobility RAZR V3
My motorola RAZR V8 has no display
unfortunately this happens frequently with the razr
(sometimes as a result of dropping, sometimes not)
if it is under warranty you can take it to a store to have it replaced
Nov 05, 2009 | Motorola Mobility RAZR V3
Screen does not light up when the phone is opened, how can I fix it?
u must have turned off the backlight go into settings then on display and turn on the backlight
Aug 06, 2009 | Motorola Mobility RAZR V3
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Motorola Razr Backlight
try a master reset if that does not work then the phone needs to be check by a professional mobile tech to determined the problem and correct it.
Sep 26, 2008 | Motorola Mobility RAZR V3
Screen will not display
I have had the ribbon cable go defective in flip phones. In some phones that I had backlight went defective. These were not all Motorola.
The fix in my phones was to change the screen and ribbon cable. If the phone was out of warranty, I retired it and bought a new one. The cost of repair was too high in relation to the repair.
Jerry G.
Apr 29, 2008 | Motorola Mobility RAZR V3
Broken backlight
if you open the v3 phone flip...you shall see 4 rubbers...remove the rubbers with a very small flat bit screw driver then unscrew the 4 screws in the phone then use the small flat bit onc more to open the phone cover, then remove the silver button on each side of the phone, unclip the cable leading to the camera and also the clip connecting to the lcd once those are removed then replace the old screen with the new one.
Dec 22, 2007 | Motorola Mobility RAZR V3
Broken backlight
  • Just get a new one
  • Buy one and replace it
  • Cry and ask your parents for a new one
  • Ask a fairy to fix it or Santa Claus
Oct 19, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Phone wont shut off
Sounds like water damage or keypad bad.
Jul 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
964 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
