Question about KEF Audio PSW 3000 Subwoofer
Subwoofer clicking noise
The sub makes a loud clicking noise as its power switches on. The noise was intermittent at first but is constant now, so unit is unusable. Any clues?
  • pcrank Apr 29, 2008
    In the end I took it to a local repair shop and paid $165AUD for a replacement PSU. The tech said that they get a fair number of these - not necessarily KEF - as Western Australia runs at 250v olts and not the rated 220-240. The replacement PSU is built to take the extra punishment. Thanks for the help.
Hi I am afraid it sounds like exactly the same problem I had, Namely the PSU(power suplly unit) is failing, This is a common fault (by reading loads of forums) I contacted KEF today about mine and they say the probably wont be able to source any more spares(due to so many having thuis problem no doubt) So I would suggest contacting the people you bought it from,Under the consumer protection act you should expect an electrical item to "Last a reasonable amount of time" .Mine is 3 years old and I do not consider this to be a long period so kick up and you should be entitled to a repair or at worst a partial refund.Look here basically the same Sub.
http://www.avforums.com/forums/showthread.php?t=436234&highlight=kef
Posted on Apr 29, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Subwoofer question
Check your wires from the amp to the sub and if possible change them. If that makes no difference the powered sub or the amp have a intermittent problem, but I think it is more than likely the sub, there are probably bad solder connections that need fixing and maybe a good time to consider a repairman to take a closer look.
Apr 01, 2012 | Audio Players & Recorders
My subwoofer constantly makes a steady intermittent buzz sound while plugged in, even while powered off.
If it has a 3 prong plug, try a 3 prong adaptor - where only 2 prongs are plugged in. Sub's should not be grounded. If it still makes a hum noise, the amp circuitry may be compromised. Replace the amp with an equal at www.partsexpress.com
Dec 06, 2010 | KLH PSW8100-8 Subwoofer
What cause subwoofer to make constant noise(loud)
usely it turn out to be a ground issue make shure there are grounded with the PROPER guage of wire or heaver the required
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
I have a Rockford PL2-110 and intermittently I get a loud popping noise out of nowhere. the sub sounds good the majority of the time but occasionally it will make the noise more and more often. any ideas?
Have you double checked the wiring ( + to + and - to -)? When hooked up correctly, a sub should push outward when bass hits. If your wiring is correct and your amp isnt too big for the speaker then its about to go out.
Jun 29, 2009 | Rockford Fosgate Punch Stage P312 D4 Car...
Crackling coming from Velodyne DD-10 subwoofer
One of 2 things is going on.
First, the servo mounted in the driver may be going bad or is picking up some noise.
Second, Something in the amp section is going bad, hard to pinpoint the exact problem.
you say that it plays, so I tend to think it is the driver mounted servo unit.
If it is within the warranty time, take the unit back to the retailer you purchased it from, if not contact Velodyne for repair.
Mar 18, 2009 | Velodyne HGS-10 Subwoofer
100watt sub
There is a problem wwith teh power supply or the amp section. Does the noise remain constant or does it vary in volume? The sub should have a level control, does the noise vary with that control?
Dan
Mar 19, 2008 | Kenwood SW-38HT Subwoofer
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
KEF Audio PSW 3000 Subwoofer Logo
2,554 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
