Question about Toshiba Satellite P105-S6104 Notebook
Rebooting Toshiba PC
Many thanks for your suggested solution. However, being a PC dummy I have no idea what you mean by BIOS or how to switch the boot device.
Nor how to ensure that its a local drive (C) and LAN boot is OFF. Are you able to run through this with me?
  • 2 more comments
  • PCdummy Mar 04, 2008
    I have MSN. The problem is I'm in Perth, Australia - so I don't know if we are going to be able to swing the time difference.
  • Adrian Coman May 11, 2010
    that would be 13 hrs ahead. we'll manage
    add me adrian_coman@hotmail.com your 8 hrs ahead.
    we can swing it. just a matter of when
    Its a little difficult to do while messaging back and forth.
    Do you have MSN / Yahoo messenger ? Any instant messaging software?
    It would help communications along.
  • 55 Answers
You should post this question to your previous problem and not open a new one so any one could see what was your problem
Posted on Apr 15, 2008
My toshiba satellite a665-s5170 when I turn it on it goes to a blank screen I tryed rebooting but didn't work please help
I suggest check your bios setup and make sure bios identy to harddrive also try the open with boot disk if working with cd you have a bad hdd
Nov 18, 2012 | Computers & Internet
Have a toshiba satetllite laptop and i have error code 0xc000000f but was not givin a recovery cd and the old press f9 is not working. any ideas?
try going into safe mode with command line utility enabled. (F8 on bootup). in command console type chkdsk /f /r and enter y for yes at the prompt. wait for it to finish, it may take a while. If that doesn't solve it try typing fixmbr. If that doesn't work, manually load the os to boot from cd-rom. tap F1 while rebooting. in the BIOS go to boot options. in boot options change first boot device to cd. put the cd in the tray, save and exit your settings. The comp will boot from the windows disk. follow the prompts.
May 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite p25-s5263 boot lockup when wireless switch on.
Try to download and install newest windows drivers for the wireless and check BIOS for wireless settings. Apart from that... stick to Linux? ; )
Nov 06, 2009 | Toshiba Satellite P25-S5263 Notebook
Toshiba A50 Not able to boot from CD
When you load the cd and reboot, when you see the toshiba screen, start tapping F12, see if this brings up the temporary boot menu, if it does choose the cd and watch closely for "press any key". If there is nothing showing, might I suggest you get an external cd drive that attaches by usb. You will then have to get back to the BIOS and set the usb as your first boot device and try to boot again from the usb cd drive. Good luck.
Oct 08, 2009 | Toshiba Sattelite A105-S2071 Notebook
BIOS issue or ? Rebooting PC into BIOS on ASUS A7V8X-X ACPI BIOS Revision 1003, 13.2.2003
If you lose time and day, means the little battery on your motherboard is done. Get a new one, replace it, should be fine then. As far as booting into BIOS, there should be a boot option, and you can boot into a hard disk, a usb or a cd rom drive. Of course in this case, choose the hard disk that has your operation system on it.
May 30, 2009 | ASUS Computers & Internet
0701 usb over current on hc/port error
I had the same problem on a toshiba satellite u400.
Usb over current on port ... blabla..
Please press F1 to resume or F12 to install.
F1 just ended up in a screen asking to press F2 or F12 which did nothing.
F12 did nothing.
Rebooting the pc ended in a black screen with a flickering HD symbol.
To be able to boot again on the BIOS I had to remove the battery and disconnect the plug.
Once It restarted booting on the error USB over current.
Si I took a USB mouse and tried to boot with the mouse plugged in on port , then another ... at the third port the PC booted normally with no error :)
Don't have any idea why it became faulty but it's now solved for me.
Mar 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Lop top dosent boot to bios, after i attempt to up grade them
This normally happens when upgrading your operating system i.e. from windows xp upgrading to windows vista. But the problems is sometimes it can skip important things or maybe you skipped on something. A likely problem is it doesnt boot after bios because the booting order is incorrect. When you boot go to your bios. im not sure what computer you have so follow the guide on this site http://www.whitecanyon.com/how-to-change-boot-order.php and the reply to this with your booting order! ONLY DO UP TO STEP 3! then if not already selected change it to harddrive but remember what it was peviously just incase this wasnt the problem. When set to harddrive try and boot again and hopefully it will work. If not then i suggest phoning up the company and asking instead of sending it to the shop as it will cost alot and they will take your computer from you!
Jan 16, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba satelite laptop
hello Mr, how are you
Mr, I, ve One problem Ihave one Dynabook satellite 1800 Laptop computer
modle name:Dynabook satellite1801 syetem Unit
Modle no: Ps183N-wzoovo
this problem is The display driver kindly you say me About this driver name nad download way
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Bios display
If you have Toshiba Console installed, you can set your BIOS to the defaults.
If not, go to:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=713852&rpn=PSA60U&ct=DL&BV_SessionID=@@@@0874164868.1224211563@@@@&BV_EngineID=ccciadefhdhmidjcgfkceghdgngdgmn.0
and download it there.
Good luck
Oct 16, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba Laptop doesnt fully boot up!
Question, does it freeze while BIOS boot or operating system boot? try reinstalling operating system and or repairing (overwriting) the MBR.
Sep 11, 2008 | Toshiba Equium 100 PC Desktop
Toshiba Satellite P105-S6104 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
