Question about Cuisinart SPB-7 SmartPower Work Top Blender
Smelly Underside Recently i noticed particles underneath the jar,where it meets the base.There is also an unpleasant smell,as the food particles are decomposing.I;ve tried unscrewing the inner nut but to no avvail.Keeping in mind that i was aware that the bottom was also rotating,is there some way of undoing it that i've overlooked?I really appreciate your time,Cameron.
  • 549 Answers
Http://www.cuisinart.com/share/man/3_man.pdf
Try this , it shows how to disassemble.
Clean with vinagar, full strength.
Posted on Mar 04, 2008
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Why does my blender leak?
hi,
sounds like the bearing assembly went, right where the motor connects to the blade, you can get a replacement base from them, have to find the model number and go to their website. doubt you burnt it up. cuisinarts supposedly are commercial quality.
jm
Jul 20, 2017 | Cuisinart SPB-7CH SmartPower 40-Ounce...
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
My 5 speed KSBS kitchenaid blender is stuck together (glass and underneath part that would fit into motor base.
Have a look at the pictures here.
I think you are describing the blade unit's gasket being stuck. This can happen over time and especially if bits of food get stuck and harden. Try soaking for a long time in warm soapy water then keeping applying pressure until the seal between the gasket and jar gives.
Feb 12, 2011 | KitchenAid KSB560 5 Speed Blender
New gasket installed but jar still leaks...Does gasket go between jar and cutter or between cutter and screw base?
The gasket goes between the plate to which the cutter is mounted and the base of the jar. i.e., atop the cutter and contacting the base of the jar.
Charlie
Jan 12, 2011 | Waring Blenders
Hamilton beach blender cleaning - food underneath cutter..does it screw off?
Usually the ring on the bottom of the jar unscrews. There is a rubber gasket beween the jar and the bottom hub holding the cutters.
Make sure you reassemble it correctly.
Apr 17, 2010 | Hamilton Beach Blenders
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Blender loud/smokes. Lost part?
you will need to buy a new blender the motor for your blender is burning and it is difficult to get parts for it.goodluck.
Mar 29, 2007 | K-Tec Champ HP3 Work Top Blender
Cuisinart SPB-7 SmartPower Work Top Blender Logo
243 people viewed this question
Top Cuisinart Blenders Experts
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
