Question about Trendware 54Mbps 802.11g Wireless AP
Can't connect to AT&T VPN
I'm trying to connect to my office VPN using "AT&T Global Network Client" and I'm getting below error:
The connection timed out waiting for the VPN server to respond. This can occur if your computer is behind a firewall that does not permit UDP or IPSec traffic. Contact your local network administrator for assistance. (229)
I'm connecting my Laptop to the Router which is connected to the comcast cable modem. When I connect my laptop directly to the cable modem I am able to get the VPN connection, so, obviously my Router is blocking some traffic.
I've tried opening up all kinds of ports and protocols but it just won't work.
I would really appreciate if any one can shed some light on this for me.
  • lombuch Mar 04, 2008
    I'm using TrendNet TEW-452BRP Router. I've browsed every single option on the admin page but couldn't find any such options.
    If you could point me in the right direction, that will be great.
  • joenges8 Jul 15, 2008
    I have the same problem, same error msg. I am using the Alcatel speedtouch 570 router. Can you kindly advise ?
    Thanks,
    Joseph
  • 50 Answers
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Posted on Mar 04, 2008
  • Michael Ansnes
    Michael Ansnes Mar 05, 2008
    Couple suggestions... first, you can try putting the machine that is trying to establish the VPN in the DMZ. This will disable the router's built-in firewall so you should consider a host-based firewall on the machine.
    Second, when I was checking out the support site at TrendNet, I found a solution to another problem that might work here. It suggested that there might be another router on your network. Check the WAN IP address and see if it is in a private range (192.168.x.x, 172.16.x.x, or 10.x.x.x); if it is, set the LAN IP on the router to be in the same subnet.
    Third, depending on the router version (C, B, or A), I found that there is an IPSec radio button on the Management tab of the web interface. You might try that.
  • Vivek Raj
    Vivek Raj Jun 15, 2018
    I am having the issue of not able to connect to AT&T and my router is DSL-224. Is there any way you can help me.
I have an older Cisco PIX 506 with two VPN connections. One links two offices (PIX-PIX VPN) together, another is for staff to access email & files. The file server on the local LAN the PIX is on are...
It could be a missing route... are the file server and email server on the same subnet? If they are then it is possibly not a routing issue.
Also it would be worth checking the tunneling settings for the VPNs... if you have specifed either only the fileserver subnet or specifically the file server address, then this could be the reason they can get to nothing else.
Hope that this has helped a little :)
Apr 09, 2010 | Cisco PIX 506E 3DES/AES bundle (chassis,...
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
I am workiong from my home office but do not get throug to my firm ofice. I am connected with sonic wall global client, but when I try to ping the firm server but it doesnt answear.
It sounds like it might be an issue with the VPN client that is attempting to get to your server at the firm. If you are having issues, first contact the firm's IT department. If they still cannot get you connected then you will need to contact you ISP to make sure that they allow VPN connections.
Nov 11, 2009 | Citrix SonicWALL Internet and...
Cannot connect to company email and network through VPN
Could you please explain me how to you are trying to establish the vpn its a site to site or site to client
another thing if you are connecting to head office through mobile user client behind any natted device you should enable nat traversal in your firewall then only i will works.
Mar 25, 2009 | WatchGuard Technologies WatchGuard Firebox...
as you told me that all the ports are open so in that case you can get in touch with your ISP and ask them to enable IPPASSTHROUGH on your office laptop.
Jan 17, 2009 | Zoom ComStar 56K 2818 Modem
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
Exchange server access problem.
If your cisco vpn client is behind the natted device then you need to allow nat traversal in the head office firewall and if you connect the vpn client through data card it will connect,
Aug 01, 2008 | D-Link NetDefend DFL-700 Firewall
Cannot connect with SonicWall VPN Client with GigaFast EE420 R
sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Jul 29, 2008 | Computers & Internet
Trendware 54Mbps 802.11g Wireless AP Logo
3,580 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
