Question about Fisher and Paykel GWL11 Top Load Washer
Filling With Water
When filling the washer machine, the washer machine keeps filling until it overflows. Do i need to replace a pressure sensor or some kind of water meeter so that the washer machine "clicks" and begins to wash the load instead of overfilling?
washung machine continues to fill with water durning the fill and wash cycle. The water will pump out durning the wash cycle to stop the machine from over flowing but it doesn't stop filling
  • rileyjo Apr 08, 2008
    GE washer will not stop filling with water. Starts to fill washer with water then moves on to my living room.
Hey i have and older washing machine and i have replaced the switch board at the back but have put the black orange white and grey wires in the wrong places in the circle bit that runs the machine.... just wondering if you could help me????
Posted on Mar 27, 2008
  • 552 Answers
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
    President:
  • Fisher and P... Master
  • 2,651 Answers
"preesure switch" built into controller, remove 2 screws behind console nad check the clear hose hasnt become diconnected, or perhaps has a crack in it not able to "read" water level
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
GENE
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
My whilpool calypso continues to fill machine with water until it overflows.
What is happening is that the fill sensor is apparently not working. The washer will continue filling until it overflows the washer!
Replace the pressure switch. This will solve your problem and cost is about $35.00
Before replacing the switch check the hose which comes to the switch also
It is possible that hose has a hole in it or has come undone. If there is no pressure in the hose, then it wont actuate the switch, and thus fill forever.
If your air tube is in good shape, it could be the switch itself, it may be adjustable.
Jul 22, 2010 | Washing Machines
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
My washing machine, dispite what water level it is set on, keeps filling and filling until it overflows. What is the problem?
Trash and sand is in the bottom of the tub blocking the pressure tube.
Remove the tube from the water level switch and blow through it to get the seddiment out. Replace the tube securely empty any standing water and retry' screw%20removal.jpg
Oct 24, 2009 | Kenmore 22422 Top Load Washer
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Filling With Water
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
May 06, 2008 | Kenmore 22422 Top Load Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
378 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
