Question about Sewing Machines
Singer 413 bobbin problem
I can't get the bobbin thread to come up through the thread plate. It doesn't even look like its doing anything in there. Isn't the bobbing supposed to be spinning or something? I got this machine second hand. It has been cleaned up and oiled and everything else about it seems fine. Maybe there is some kind of trick about getting the bobbin thread to pop up--it's an old machine-maybe they're different? Thanks for any help/advice you can give.
  • beagleface Apr 13, 2008
    I have the same problem. The free diagram is very helpful but I am having trouble with the tension spring. I pull the bobbin thread towards where I think the tension spring is but it ends up breaking the thread. Is there a trick to catching the tension spring?
  • Anonymous Mar 14, 2014
    Please help me. I have looked at everything possible bobbin etc th readings of machine. Bobbin thread cannot be pulled through to the top. Maybe it is just getting to old it is over 20 now.
  • 57 Answers
Have a look at this free on-line manual here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_413_threading_diagram.htm
It should answer your question. Yes, old machines are different! :-)
If you found this helpful, please Vote! Good Luck!
Posted on Mar 04, 2008
  • rob_rtac
    rob_rtac Mar 04, 2013
    This is NOT a solution. If the gears are not spinning down below, its NOT a problem with the way you are threading your bobbin. IGNORE this as a solution.
2 Suggested Answers
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
Posted on Jul 31, 2011
Big loops under the needle plate. The bobbin case is pulled towards the needle and lifted up in the front.
OK, Nylon thread and vinyl fabric are difficult. Try this:
1. Be sure your machine is *very* clean - no leftovers from previous projects.
2. Take the bobbin receiver out (need a screwdriver to hold the release), clean it and all around it and re-insert. When you re-insert in this machine, hold the release lever with the screwdriver, push the receiver away from you (under the feed dogs) then bring it back toward you so it catches before you release the catch.
3. Use a stitch length just a bit longer than you 'normally' would - 3+ for vinyl.
4. Wind your nylon thread onto a bobbin *very* carefully. It's easy to get it caught so that it won't feed evenly.
5. Be sure your upper thread is in properly, and that it doesn't catch on anything.
6. Adjust your upper tension tighter than 'normal' to accomodate the slippery thread your're using - do this a little at a time, it's easy to miss the 'sweet spot' if you adjust too much.
7. Be sure to bring up your bobbin thread and hold both threads as you start to sew - hold them for 3-4 stitches.
8. Sew slow - this machine can go *really* fast, but don't let it on this project. It will catch better if you take it slow and easy.
Hope all this helps. If not, you'd probably better take it in for service.
Aug 29, 2012 | Singer CG590 Mechanical Sewing Machine
How do you thread thre bottom bobbin on a singer 533?
Drop the bobbin in, holding the the of the thread between your left hand fingers, making sure the bobbin will turn clockwise as you pull on the thread, manually turn the wheel to make the needle go down and up again, as it comes up it will bring the bobbin thread up through the plate hole. There you are, close the plate, good sewing
Aug 10, 2010 | Singer Drop-In Bobbin 758B-28BH Mechanical...
I have a Singer mod 9134 sewing machine. It keeps
Try inserting the bobbin in the reverse direction. Most machines take a bobbin clockwise or counterclockwise and it can make a difference. Also try a new needle, a bad needle is often the problem believe it or not.
Nov 10, 2009 | Sewing Machines
Bobbin case turns in its place
You need to remove the needle plate and take out the bobbin case. Examine it for any rough spots, scratches or burrs. When you find them, you will need to remove them with an emery stick and then buff it with very fine steel wool. Reinstall the bobbin case and the needle plate. Put the bobbin in the machine so that it turns counter clockwise when you pull the thread. Rethread the top of the machine and change the needle. Hold the needle thread , turn the handwheel and see if the bobbin thread is picked up without snagging anyplace. If it's okay, sew away.
sewman7
Jul 14, 2008 | Singer 7422
Sewing Machines Logo
1,070 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
