Oil is leaking from bottom of our maytag washer...model number PAV5158AWW...what do you think it is and how long is the warranty on this?
    President:
  • Washing Mach... Master
  • 2,651 Answers
Would depend on date of perchase, everything produced after jan 06 is strictly 1year warr on everything, no extended. but prior to that transmission had multi year heres a copy of owners manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/35-6451.PDF
Posted on Mar 04, 2008
How do I take the loader part of a Maytag PAV5158AWW out to get to the motor
I'm not sure what you mean by that but I'll tell you how to get to the motor. What your going to want to do is remove the front of the washer, which if I remember right has two screws in the front near the bottom. Then you pull the bottom out towards you and thats it. The motor will be right in front of you on the right hand side. The belt that drives the pump and transmission by means of the motor is under the washer, so just tilt it back. The belt rolls on and off easily.
Apr 29, 2012 | Maytag Washing Machines
Washer makes a loud whineing noise when spinning or aggitate , oil on floor under washer, can you refil the transmision with oil
The transmission has a 10 year warranty, and you cannot refill without tearing it down. Check your owners manual for remaining warranty or call 1-800-253-1301 and they can tell you. They will need your complete model number and serial number.
Jan 13, 2011 | Maytag PAV2300 Top Load Washer
Water leaking out of bottom
Is you machine model a FAV6800A or FAV9800A?
If so post back with the model number and I will try to help.
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Leaking drum on maytag washer.
Go to www.repairclinic.com and enter MAV6000. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and replacement.
May 23, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Jan 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Oct 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag SAV washer leaking all over floor
I have the exact same washer with the exact same problem. I have a home warranty that covers appliances so when they sent out the Sears technician, he took a list of parts and replaced about 9 things for a grand total of $450. If I didn't have a home warranty that only charged me $55 to do it, I would have just bought another non-Maytag washer.
Jan 23, 2008 | Maytag Legacy Top Load Washer
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
