Question about Mitsubishi WS-65809 65" Rear Projection Television
REPLACING LAMP I HAVE BOUGHT A NEW LAMP FOR MY PROJECTION TV AND NOT THE WHOLE CARTRIDGE. HOW DO PUT IN THE NEW BLUB?
  • 979 Answers
You will have to extract the old lamp and utilize that original part to make this repair...accordianman
Posted on Mar 04, 2008
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
How to replace the lamp in tv
Google the model number for instructions and You Tube does have video instructions for several brands and models online.
Dec 15, 2012 | Mitsubishi WD Televison & Video
Replaced lamp, pic is dull and not sharp any more,
Did u unplug the tv about half hour before u change a new tv projection lamp,for the tv so the tv power storage left over to disapper and what ever statictic charges magnatic field left to completely gone or to lower it enough not to harm the new tv projection lamp u just starting to put it in wright?The new projection lamp when u handleling it did u have a pair disposable glove on to not causes human static charges and the oils from ur hand to tranfer to the new tv projection lamp itself to caused to it quality funtions?This is the same exact same brand and make to the tv old projection lamp u are replacing not a clone or a tv compatible tv projection lamp wright?U check all connections are correctly installation and tightly before u turn on the tv again wright?U do all these safety procedures,before and after u are replacing a tv projection lamp will help 90-95% it to work correctly,if the tv causes are just requiring replacing a new tv projection lamp only.
Oct 06, 2011 | Mitsubishi WD-62531 Projection Television
Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Jul 04, 2010 | Akai PT61DL34 Television
Have lamp message in JVC HD-52Z585 to replace lamp #TS-CL110U.
I would, it's cheaper than replacing the whole TV and you can do it yourself so no labor bill. The new lamp usually comes with directions and in my experience the JVC lamps are outlasting some of the other ones.
Sep 10, 2009 | JVC HD-61Z786 61" Rear Projection HDTV
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Product- 50VS810 Hitachi TV Replaced burnt out
check your lamp and lamp door saftey switches. If they are ok then could have also got the ballast.
Aug 09, 2009 | Televison & Video
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
May 07, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Replacing the lamp
Should be a pretty simple matter. There is a door on the back left side.
Did you buy a lamp or a lamp and housing?
DO NOT TOUCH THE LAMP BARE HANDED!!!
Dec 11, 2008 | JVC HD-61Z786 61" Rear Projection HDTV
Reset for new lamp
take the lap back out and put back in
After replacing the lamp cartridge, when you power on the TV, the message "Did you change the lamp? Press ENTER for Yes, press CANCEL for No"will appear, press ENTER to reset.
Feb 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
