I am having trouble getting my laptop to connect to the wireless router. It worked before but now I can't seem to get to the set up wizard to re-establish the link. It's a DI-624 D-Link router and it may be something to do with not recognizing the IP address but not sure what to do. Our other laptop is working fine so I don't think its the router. Any help would be appreciated. Thanks
  • ronamken Mar 04, 2008
    I'm right beside it so I guess what I need to know it how to get the right IP address?
    Sergeant:
    Champion:
  • 281 Answers
Try to make sure that you got the right IP adress, and also try to be closer little bit to the wireless router.
Posted on Mar 04, 2008
I have installed, set up, and created my router's name, password, and key, but im still having trouble connecting to the internet. The little icon that looks like the earth is glowing orange, and the only...
Use the network setup wizard to connect to your network, and the internet. Unless you did this already.
You can get the wizard from Control Panel, Network ... , Connect to a Network. If wired you won't need key, it's for wireless only.
Yo did not say what OS, so info is a little generic.
Hope this helps.
Jan 26, 2011 | D-Link DIR-615 Wireless Router
Router connection problem
you will not see your router in any of the places you looked.
Easiest method:
Shutdown your PC and laptops. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC and laptops. The PC and laptops should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 29, 2009 | D-Link DI 514 Wireless Router (DI-514)
Can't get my wireless laptop to work. How do I connect the router to the computer?
First what type of router do you have? What is the model number?
Second ensure that your wireless switch (if your laptop has one) is set to on.
Go into view network connections and ensure your wireless card is enabled.
From you Desktop ensure that you are connected as described in the previous post.
Depending on your router make and model type in the ip address to the router.
Default for linksys is usually 192.168.1.1
DLink is usually192.168.0.1
From here it depends on your specific router.
There should be a wireless setup wizard.
Apr 23, 2009 | Computers & Internet
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Mar 23, 2009 | HP Pavilion dv9000z Notebook
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
WIRELESS SETUP CONNECTION FOR TOSHIBA TE2100
Go to the control panel. Open wireless connection wizard and configure it by giving the proxy setting of the router. There must be a DNS server to get you connected with the Domain.
First your os xp or vista
if u xp means go to network connection and see that tab, wireless network wizard and click next to open to next to next and click finish. It will appear in network connection windows. But u want to take airtel broad band wireless net key, and u open the tab if u finish ur network wizard tab. And it will open the icon it ask for key, u give it key to continue. It will ready to access the network, so this is the way
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 30, 2008 | Toshiba TE2100 Notebook
My laptop won't work wireless
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Jan 23, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
