Question about Asko 24 in. D3250 Built-in Dishwasher
Asko d3250 i think dont have water presure because he take the water inside and then star the cycle and drain the water but i think the blades dont run i lisent a smal noise of water
  • 552 Answers
First I would check the water line from the sink that is hooked up to the dishwasher.
You may have a screen that plugged up.
Also, if you have little pressure at your sink faucet, then you should check your house's water system.
Posted on Mar 04, 2008
Asko fifteen eighty five dishwasher completes cycle, but the drain cup area still has water in it.
The drain cup normally has water in it after it drains. The pump runs it empty, but when it stops, some water runs back down from the drain hose, which you see in the drain cup. If there is water in the bottom of the tub, you may be having some siphoning coming back after draining. Check to make sure the drain hose has been routed up to the bottom of the countertop as per the installation instructions. That's what prevents siphoning, and its very important so it doesn't suck sewer water back in with the clean dishes!!
Jul 08, 2014 | Asko 24 in. D3250 Built-in Dishwasher
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Our Asko D3250 dishwasher is brand new, and it fills up and drains and fills again and then the water inlet fault flashes. It doesn't go past this point.
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Dec 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Fault indicator on Asko D-3250 (heavy wash/ too much water has en
the float switch must be stuck the up position or water inside the pan or a bad float switch..
hope it helps.... if NOT let me know more about your problem...
Sep 25, 2009 | Asko 24 in. D3250 Built-in Dishwasher
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
ASKO D3250 Does not run
HI thanks for your question. the problem is with the water pump. its electric, so some of the food got caught in the pump. clean out the pump. thanks, the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Asko W6661 Front Load Washer
ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Jan 19, 2008 | Asko 24 in. D3250 Built-in Dishwasher
D3250 drain blocked error
usually these are blocked at the discharge end under the sink, especially if the hose is hooked to a copper pipe then shoved down the plumbing standpipe. It could also be in the hose behind the dishwasher if someone has fitted an extension onto the hose and used a small diameter coupler. Run the dishwasher on any cycle...if there is standing water you should hear the drain pump run first...if there is no standing water run it on a rinse and hold cycle. at the end of the cycle the pump will run. if you hear the pump, but no water is ejected out the drain hose under the sink, then you most likely have a clog in the hose near the end or in the middle if it has an extensio. if you dont hear the pump run, then its a bad pump and you need a new one (parts like that are covered for 5 years if you use an ASKO servicer) Good luck!
Nov 03, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
171 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
