Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Brother Intellifax 775
On the dial pad the "1", "2" and "3" do not work, you push them but the machine doesn't recognize it/it doesn't register. If you have to dial a number that has 1, 2 or 3 in it you are out of luck! Also, the top two one touch keys over at the left do not work either. So it appears that the entire row of buttons do not work.
  • 682 Answers
1-use air blower to clean it.
2-use dry contact cleaner to clean it.(radio shack)near to you.
3-if you have previous experience in machine open it and disassemble key pad -wash it carefuly with water and dry it and bring a tracking pen(also from radio shack and apply the pen in pads of numbers 1-2-3.
Posted on Mar 04, 2008
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
How to change date and time on the Brother Intellifax-2820.
1 Press Menu/Set.
2 Press 0.
3 Press 2.
4 Enter the last two digits of the year on the
dial pad, and then press Menu/Set.
(e.g. Enter 0, 7 for 2007.)
5 Enter the two digits for the month on the dial
(e.g. Enter 0, 3 for March)
6 Enter the two digits for the day on the dial
(e.g. Enter 0, 1.)
7 Enter the time in 24-hour format on the dial
(e.g. Enter 1, 5, 2, 5 for 3:25 P.M.)
8 Press Stop/Exit.
Jun 11, 2010 | Brother IntelliFAX 2800 Laser Fax
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 1840C says to change yell even though its full
Your machine did not recognize the new cartridge. Remove the yellow, count to 10 then replace it. The machine will ask "did you change the color yellow?" Select yes by dialing "1" - if after the cleaning cycle "near empty" still appears, you need to contact Brother for repairs. You can safely use the machine until "INK EMPTY" appears.
Mar 30, 2009 | Brother IntelliFAX 1840C Plain Paper...
Time Change on Brother 2820
1.Press menu
2.Press 0
3.Press 2
4.Enter the last two digits of the year on the
dial pad, and then press Set.
5.Enter the two digits for the month on the dial
6.Enter the two digits for the day on the dial
7.Enter the time in 24-hour format on the dial
8.Press Stop/Exit.
Feb 26, 2009 | Brother IntelliFax-2820 Laser Fax
Brother intellifax manual model 775
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Mar 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax installation
There is no installation CD for this machine. The machine sends, receives and copies. The machine will not connect to a computer and does not need a CD to perform it's functions. Years ago Brother had a 770 which is the father of 775 that connected to a computer by purchasing software and a cable(PCI-1). This software is outdated and does not work well with any of the current windows programs. Most Brother ink-jet and laser products will connect to a computer via an installation CD or down loading the drivers from Brother.com. None of their thermal machines will connect to a computer.
Sep 20, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Unable to get my Intellifax 775 to receive any fax's
Make sure that the phone line is pluged into line on fax machine and not ext.
Mar 18, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
