Question about Logitech diNovo LX300 Keyboard/Mouse
YRQ52 hello i have a logitech mouse and key board. my problem is my cursor is frozen. i replaced the 4 batteries, sync all the buttons, and rebooted the pc. the unit is about nine months old. i also checked all the connections the green wire with the pins is is not plugged in but the usb wire is. thanks houndd@embarqmail.com
simplemitch
  • 752 Answers
SOURCE: Dead Mouse
Try different USB jack. Try fresh batteries. Re-install software.
Posted on Sep 22, 2007
  • 38 Answers
SOURCE: logitech mouse problem
sounds like you have reverse mouse enabled  go into the control panel find the properties for you mouse, this should be a check box you can disable.
Posted on Oct 25, 2007
SOURCE: Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Posted on Oct 30, 2008
  • 341 Answers
SOURCE: Logitech S510 mouse will not turn on
I am assuming since you need batteries that the mouse is cordless. If so you normaly have to sync the mouse with the receiver.If the keyborad and mouse came as a package it will only have one receiver.There should be corresponding sync buttons for these devices.
Posted on Nov 26, 2008
preachw996
  • 1179 Answers
SOURCE: EX-110 Logitech cordless optical mouse: does not work
There should be a battery compartment on the bottom of the mouse. Replace batteries and make sure you setpoint software from logitech is installed. Hope this helps.
Posted on Dec 26, 2008
I need to replace the batteries to a cordless logitech mouse, where are the buttons located on the wireless keyboard to sync everything back up? And how long do I hold buttons for?
I used to use a set of these
the button on the key board should just be on the bottom, if you dont see it it might actually be in the battery compartment. but im pretty sure its just on the bottom it might even be red.
to sync it, have the receiver plugged into the computer and the computer on. push the button on the receiver until the little green light flashes on the receiver then press the button on the keyboard, the light should stop flashing and the keyboard should by synced, do the same with the mouse.
Mar 26, 2011 | Logitech Cordless Mouse
Logitech mouse is'nt working
You might try re-syncing the mouse with the wireless sender. Push the button on the sender (plugged into usb port usually) and then push the button on the bottom of the mouse.
Aug 02, 2010 | Logitech Cordless Mouse
How do I connect my wireless mouse and keyboard?
If it came with the install disc you will need to use it, also, (newer computers will detect the software automatically) you must sync your key board with the mouse.
#1 press the connect button on receiver
#2 Press the connect button on the mouse
#3 Press the connect button (again) on the receiver
#4 Press the connect button on the keyboard...
DONE
May 29, 2010 | Logitech Cordless MX 3200 Laser Mouse
Mouse does not move cursor. Has new batteries.
Hello
There is a small reset button on the bottom of the mouse push and hold it in for a couple seconds.
You would need to download and install software and drivers for mouse from the manufacturer to get a battery saving option.
Mar 21, 2010 | Logitech Cordless Mouse
Can't change battery in optical mouse hub
no. But you may have to press the button on the bottom of the mouse and on the receiver at the same time. To re-sync them.
They are matched by syncing the code from the button, so you don't move neighbors cursor around :-) .
Cheers
Sep 29, 2009 | Logitech Cordless Mouse
Mouse pointer frozen
I would try re-syncing the mouse. If it doesn't work right away, try a reboot and then syncing the mouse. There is a little button on the bottom of the mouse that will allow you to do this.
If you need me to go further in depth i certainly will - just let me know but I would say that it's probably your problem.
Let me know if this works or not so i can try to find the correct solution if this doesn't to it for you. I'm here to help!!
Aug 15, 2009 | Interlink Mouse
Dell wireless mouse cursor froze in middle of screen.
Hi, my cursor had frozen on my screen after my grand daughter pressing something. After trying everything I decided to take it to a local computer shop, it was fixed in seconds. He held the arrow tab(below the caps lock tab) and then pressed F9 it worked!!
Hope this will fix your problem
Jul 27, 2009 | Logitech 3-Button Cordless Optical Scroll...
Logitech MX 5000 Wireless Laser Keyboard & Mouse Combo
HELLO, ALL YOU HAVE TO DO IS TO DOWN LOAD THE SOFT WARE THEN PLUG IN THE USB AND AFTER THAT ON YOUR RECIEVER CLICK THE CONNECT BUTTON ON THE RECIEVER TILL IT RECONIZES BOTH KEY BOARD AND MOUSE I HAVE THE LOGITECH WIRELESS SYSTEM AND I LOVE IT TILL THE BATTERIES GO OUT ON THE MOUSE OR KEY BOARD LOL THEN RESTART YOUR COMPUTER.
Apr 05, 2009 | Logitech Cordless Mouse
Oct 07, 2008 | Logitech S 510 (967555) (DH967555)...
Logitech diNovo LX300 Keyboard/Mouse Logo
523 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
