Question about Hoover Company Wind Tunnel U53019 Upright Vacuum
Windtunnel Light Vacuum Belt
How to change a broken belt when I can't find my owner's manual
    President:
  • 1,673 Answers
Take off the bottom plate, you will see the brush roll and old belt, If you can reach the motor shaft, then put the belt over it and then over the brush rol and stretch to fit back in the slots fot it. If you don't see the motor shaft, then you have to remove the top cover to get to it.
Posted on Mar 04, 2008
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Yes, you probably need to replace the belt. Below I have listed a link to the owners manual which has instructions on how to change the belt and a link to the replacement belt you need. Hope it helps you!
Eureka Capture Owner's Guide
Eureka Capture Replacement Belt
Nov 01, 2009 | Eureka Capture Upright Vacuum Vacuum
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Change belts on a Hoover Power Drive Wind Tunnel Series 900 vacuum
Try calling Hoover directly toll free at
1-800-944-9200 M-F 8 AM - 7 PM EST.
Sep 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Mar 24, 2009 | Hoover WindTunnel V2 U8148-900 Upright...
Hoover Company Wind Tunnel U53019 Upright Vacuum Logo
54 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
