A USB data cable is supplied with the KP199 mobile phone. Just connect it while the mobile and PC are ON. The phone will ask a question whether to use the phone as a data storage or as a modem.Select Data Storage. The phone memory and the MicroSD memory will be displayed as separate disk drives on the PC.
There is two main ways that you can transfer photographs to your laptop;
USB 2.0 Full Speed for rapid music transfer
Nokia Connectivity Cable CA-101 - High-speed data transfer This
micro USB cable provides high-speed USB 2.0 data transfer rates, and
enables charging your compatible device or enhancement from a laptop or
PC USB port.
Bluetooth 2.0 with stereo audio profiles for wireless music listening and control.
Because your question is NOT so accurate and clear, I will bring out to you the following scenario:
1- In case you have a problem in the electrical wired cable itself that hold the transfered power to charge the laptop battery then you can't do anything except buying another electrical charger.
2- In case you have a problem with the laptop battery, you can simply remove that battery and straightly connect the electrical wired cable to the slot power of laptop.
3- You recommended charging your batter with the USB cable, which is impossible due to the following reasons:
a) USB cables assemblies are used in the transmission of data across networks in case they are network
b) Cable assemblies are collections of wires or cables banded into a single unit with connectors on at least one end.
c) USB connectors are used with universal serial bus (USB) ports. They can be used to connect USB products together, or to connect USB wires and peripherals to other standard port types.
d) The cable assembly may be used for various computer applications like connecting mice, keyboards, printers, modems or other peripheral devices.
The concept of the above description is that you need a cable that transfer to you a specific voltage from a generated magnetic chain to the receiving destination.
Therefore, USB cable have a huge difference in the capacity of the Electricity cable, where USB cables are for data transfer, and Electrical Cables are for Electric Power Voltage (EPV) Transfer.
I know that you haven't ask for all of this, but the main idea of my explanation is to clarify on why there's NO USB cable that can charge your battery, and those that are charging your phone are doing that through the very low voltage that comes from the vibration of chain magnetic into the USB cable transfered from a higher voltage i.e. Computer, Socket Power, etc...
hi,when you connect it it asks for 1.mass starage 2. com port u have to choose mass storage then start transfering data from pc to mobile.............if its not detecting then problem with ur handset connection port(hardware prob).....
my motorola l6i cannot connect with my pc through data cable. so pls give me USB Data transfer sotware .................send software on my e-mail [email protected]
did you connect directly to your laptop or you connected via external USB Hub?? Your notebook model should support USB 2.0 ...so it should not face the problem you post..unless you're not connecting it directly.
takecare.
