Question about HP DeskJet 722c InkJet Printer
HP Deskjet 722C printer belt has frayed and come apart
The belt which moves the carriage with the printer cartridges has frayed and come apart. Can it be replaced?
  • Irebel Apr 08, 2008
    I have a 830 deskjet with the same problem. The part is worth far more than the printer. The cheapest so far I have found was 30.00 + shipping. So... I am looking for a used one that has the same Carriage Drive Belt that I can use. I went to http://www.everprint.com/printer/deskjet... and found my printer and the part no. The site mentions all the printers that part will fit. So now I can scout around and see if I can find one.
    The only reason I am going through all this trouble is that I have just bought 2 sets of ink cartrigdes for this printer. They cost more than a new printer.
    Good luck
    Master:
  • 351 Answers
Dear DIOGENES2001 ,
Yes , please contact nearly Authorised Service centre for genuine spare .
Cheerup
Posted on Mar 04, 2008
I recently bought an HP deskjet 810c at a yardsale-- I already have a HP deskjet 722c so I am familiar with the design. The printer seemed to react ok when I powered it up (cartridge came to the center...
Hello cmcclung147
You certainly didn' t mess up , I can assure you .
Generally , with power of and gently lifting the carriage and manually moving it from left to right and/or vice versa , plugging power back on , solves the problem . I succeeded that way with my 930C . Should work with your device .
Good luck !
Best regards ,
fanaudi .
Apr 28, 2011 | HP DeskJet 940c InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
The print cartridge will not move
There is a "belt" (with pulleys at each end, and the carrridge in the middle) that pulls the carriage from edge-to-edge.
If that belt is broken, or the clamp that connects the belt to the carriage is broken, the carriage will not move.
It's cheaper to replace the printer, and responsibly recycle the old printer, than it would be to try to repair the printer.
Jan 05, 2010 | HP DeskJet 5650 InkJet Printer
When I turn it on, the ink cartridge does not move to the center, and the green and orange light both blink. It won't print
That condition would seems to indicate a paper jam or carriage stall on your product. HP support has the following information here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09131&cc=us&lc=en&dlc=en&product=57565
Dec 06, 2009 | HP DeskJet 722c InkJet Printer
Replaced ink cartiage and now there is a blinking orange light
Replaced ink cartridge is black or color. change another one. if not solve change carriage unit
Thanks
Sk. Abdus Sabur
Nov 30, 2009 | HP DeskJet 722c InkJet Printer
All three lights flashing, tray for cartridges inside housing
You have a faulty carriage mechinism in your printer. you can try putting a drop of sewing maching oil on the carriage rail (the silver bar inside the printer that the head goes back and forth across), but if this fails, your unit is not repairable as hp do not supply parts for their inkjet range of printers.
gremlin 11
Dec 11, 2008 | HP DeskJet 722c InkJet Printer
HP Deskjet 722C
I would try to clean the contacts that go against the cartridge.  Use rubbing alcohol.
Oct 26, 2007 | HP DeskJet 722c InkJet Printer
Printer problem
You'll need to clean the encoder strip, encoder wheel, paper feed rollers and the carriage rod (where the cartridges ride -plus lube this) and cartridge service station. If you can't figure out how to do this, you'll need a tech that knows how. It will get pretty involved and I would recommend getting a new machine because they have come down in price and you could replace this for very little.
Jul 27, 2007 | HP DeskJet 722c InkJet Printer
HP DeskJet 722c InkJet Printer Logo
129 people viewed this question
Ben Johnson
