To access the router setup, open an IE browser, on the address line: http://192.168.1.1 then press enter, you should be prompted for a username and password, leave the username blank, password is: admin, this should give you access to the router.
http://en.wikipedia.org/wiki/Linksys_WRT54G_series#Default_settings
if for some reason that doesn't work, start, run, cmd, enter, this will open a command window and type the command IPCONFIG /ALL look up the default Gateway IP address and see if it is different. If the gateway is a different IP address, try that IP address
