Question about Lands Phones
I have 8825 Siemens 2 lines multi handset system. I can not delete and re-record the message for caller to call me. The old recording can not be deleted. Please help.
  • azharian Mar 04, 2008
    on the base station I enter menu,select,I get greeting, select, I get mail box 1 or 2, select, I get play greeting, record greeting,
    What am I doing wrong?
    thank you
    Sergeant:
  • 395 Answers
On the base station enter the menu go to answering systems menu, go to the "mail box" or "answer only greating" or "blocked ID greating" or "line attendant greating" select delete for the desired greating. the delete greating only shows up if there is a greating present. appenex c of the manual.
Posted on Mar 04, 2008
  • 2 more comments
  • Robert Johnson Mar 04, 2008
    sorry hit post it too quickly after deleting the greating re-record it as per instruction on page 55 and 56 of the manual.
    check the other greatings such as "answer only" greating, and so on. each of the types of greatings have there own settings. if a greating is recorded in that type the "delete greating" will be there. if no recording is there the only option is "record", "play back". there must be a recoring there in order to delete. so check the other types of greatings.
  • Robert Johnson Mar 10, 2008
    how have you made out on your problem was I able to help?
  • Robert Johnson Mar 16, 2008
    please rate the solutions we need your help as well as you need ours.
    Genius:
  • 1,226 Answers
Hello!
Please unplug/reset the siemens and disconnect all connection and wait for a while reset it automatically.
may this help. melnavz
  • Emelio Navaja
    Emelio Navaja Mar 04, 2008
    thats good
    bobbyj continue what you doing. i am sleepy.
Gigaset 8825 answers phone but does not record message
Some Gigaset phones have an option to have the answering machine play an outgoing message only without taking a message. You should check your settings and make sure you don't have yours set up this way. This could also happen if the memory for the answering machine is full so that it cannot record any more messages.
Sep 01, 2014 | Siemens Gigaset 8825 Cordless Phone
Message light keeps blinking even though there are no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 23, 2014 | Uniden DECT1580-2 DECT 6.0 Expandable...
My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
I hope this helps.
Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
HI! How do I change the message on my phone?
You can record your own greeting message (max 2 mins & 30 secs). If you don't record a greeting mesage, a pre-recorded greeting message is used & asks the caller to leave a message. (Make sure your phone has the correct date, time, year, etc.)
To record a message:
1. Menu (OK) the "Answering Device" (OK), the "Record Greeting" (OK)
2. Then after the handset beeps, speak clearly about 20 cm (8 in) away from the mike.
3. To stop recording, press (OK)
4. (Off)
Mar 30, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Change recorded message
Please follow the steps:
1. Press MENU
2. To select "ANSWERING SYSTEM MENU?", press SELECT
3. Scroll to "GREETINGS?" and press SELECT
4. Scroll to type of desired message and press SELECT
5. Scroll to "RECORD GREETING?", and press SELECT
6. Record a message or greeting through the base speakerphone or base station handset. 7. Press SELECT to play back greeting/ message.
NOTE: To avoid background noise, record message through the corded handset.
Sep 12, 2009 | Siemens Gigaset 8825 Cordless Phone
I do not want mailbox selection as part of recorded message
I'm no expert, but I have had a lot of trial and error experience with this set. Is your Auto Attendant on? This feature is designed to be like an operator for multi mailboxes. If it is, turn Auto Attendant off and record the greeting for mailbox 1. Hope this helps!
Dec 23, 2008 | Siemens Gigaset 8825 Cordless Phone
Retrieving message
First set up a pin # or use the default which is 0000.
Then from a remote location:
  • Dial the Number
  • Press * Twice before the greeting is completed
  • Enter the Pin
  • Select * to hear all messages or Mailbox number which you are calling to check
  • Use the menu below:
5 - Play New Messages
6 - Record Message
7 - Play All Messages
8 - Play Greeting
9 - Record Greeting
0 - Turn System Off
# - Access help
Sep 17, 2008 | Siemens Gigaset 8825 Cordless Phone
Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Siemens 8825 gigset 2 line phone
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Sep 04, 2007 | Siemens Gigaset 8825 Cordless Phone
Lands Phones Logo
85 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
