Question about Sony Cyber-shot DSC-W100 Digital Camera
MY mode-selection switch glitches
My mode selector switch thinks i'm turning it when i'm not. it's VERY annoying and will "switch modes" while im reviewing photos in "playback" mode. it will also switch it up while i'm trying to take a photo!
i'm hoping its just dusty, should i squirt some "electronic switch lube" in there? i dont want to Fubar my camera but sony didn't fix it when i sent it in....
  • 6 more comments
  • Anonymous Mar 12, 2008
    This seems to be a problem for every single person who has this camera.
  • Figit090 Mar 21, 2008
    can we do anything about it?
  • lazyd Mar 21, 2008
    This started a few weeks ago. Is there any solution?
  • lazyd Mar 25, 2008
    i chatted with sony about this and they suggested i re initialize the camera. (all settings are lost). i did so and it seems to work for now.
  • dreamattack Mar 26, 2008
    ugh i have the same problem too! should i just move on from this camera? i've loved it up until now!
  • puntel Feb 19, 2009
    I had the same problem and the solution of "Initialize" worked!!
    Menu -> Setup -> Setup 1 -> Initialize -> OK
    All settings will be restored the default values, but nothing hard to configure again, right?!
    Thanks!
  • Anonymous Apr 01, 2009
    I had this problem for over a year! Very annoying!!!! The init fixed it for me! Works perfect now! THANK YOU!!!!!
  • Anonymous Apr 08, 2009
    Awesome. I had the same problem and was just dealing with it for the past two years. I'm glad you posted this easy solution.
I have a Sony DSC W100 and had a similar problem. On one of these post there was a solution which worked for me. It stated to reset the camera and on the Sony if it is a reset button, it was located inside the battery/memory card slot. It is located to the left of the memory slot a little gray dot.
Posted on Jul 21, 2008
2003 CADILLAC DEVILLE DTS CAR SHOWS IT IS IN DRIVE BUT IT IS IN PARK AND WONT START AND CANT GET KEY OUT OF IGNITION???
Re-adjust the shift linkage to set the lever higher so it is in park when the indicator says it is. Until you do this adjustment on the linkage, the key will be locked in the cylinder. The shifter lever MUST be ALL the way up to park position in order to remove the key.
May 02, 2018 | Cadillac Cars & Trucks
05 Buick Rendezvous shift indicator does not light and engine will not crank. Can disconnect the battery and reconnect and most times it will start. Would this be the neutral safety switch and if so is it...
Could be a number of thing's ? The electronic's on your vehicle are very complex ,taking to a qualified repair shop an having it checked for DTC'S - diagnostic trouble codes would be your best bet . The internal mode switch as it is called ,is a input to the PCM - engine computer . The PCM sends the gear position over the class 2 serial data network to the instrument cluster . The instrument cluster has a microprocessor inside which will use this info to select correct gear position . Replacing parts that will not fix the problem isn't the way to a fix. Knowing GM vehicles an the problems they had with instrument clusters from 2003 to 2006 ,i would suspect that as being the problem . Having a professional type scan tool an checking for DTC'S in the instrument cluster as well would be the first step to do.
The transmission internal mode switch (IMS) is a sliding contact switch attached to the selector detent inside the transmission side cover. The 4 inputs to the PCM indicate the position of the transmission range selector. The input voltage level at the PCM is high, B+, when the IMS is open and low when the switch is closed to ground. The 4 input parameters represented are Signals A, B, C and P, Parity. Refer to Transmission Internal Mode Switch Logic .
Before replace parts ,hooking up the scan tool
Install a scan tool.
Turn ON the ignition, with the engine OFF.
Select IMS on the scan tool.
Place the range selector in each transmission range: P, R, N, D4, D3, D2 and D1.
Does each range selected match the scan tool IMS display?
At the dealer we test ,not guess .
Mar 17, 2018 | Buick Cars & Trucks
Codes 1826, 1825 and 1819. Car wont start. Do we need to remove trans to reset? Trans was used.
DTC P1819
Internal Mode Switch-No Start/Wrong Range
DTC P1825
Internal Mode Switch - Invalid Range
DTC P1826
Internal Mode Switch C Circuit High Voltage
The transmission internal mode switch (IMS) is a sliding contact switch attached to the selector detent inside the transmission side cover. The four inputs to the PCM indicate the position of the transmission range selector. The input voltage level at the PCM is high (B+) when the IMS is open and low when the switch is closed to ground. The four input parameters represented are Signals A, B, C and P (Parity). Refer to Transmission Internal Mode Switch Logic
Install a Scan Tool . A professional scan tool !
Important: Before clearing the DTC, use the Scan Tool in order to record the Freeze Frame and Failure Records. Using the Clear Info function erases the Freeze Frame and Failure Records from the PCM.
Record the DTC Freeze Frame and Failure Records.
Clear the DTC.
Select IMS on the Scan Tool .
Place the gear select lever in PARK range, then move to NEUTRAL range.
Does each range selected match the Scan Tool IMS display?
.Replace the lever assembly-manual shaft detent with internal mode switch.
Refer to Transmission Overhaul in the 4T65-E Section of the Transmission Unit Repair Manual.
Mar 15, 2016 | 2001 Buick LeSabre Limited
How do I switch my surround from off to on Harmon avr347
Surround modes are selected using either the front panel controls or the remote.To select a new surround mode from the front panel,first press the Surround Mode Group Selector Button5until the desired major surround mode group such as Dolby,DTS or Logic 7 is selected.Next,press the Surround Mode Selector Button9to choose the specific individual surround mode.
Aug 19, 2014 | Audio Players & Recorders
2003 buick rendezvous wont crank. error on prnd123 display
The proper thing to do would be to hook up a factory or professional type scanner an check input data to the PCM from the Transmission internal mode switch . Error means the instrument cluster is loosing data from the PCM - engine computer .
The lever assembly-manual shaft detent with internal mode switch (IMS) is a sliding contact electrical switch assembly that corresponds to the PRNDL position selected. Each of the PRNDL positions has a unique ground pattern on four wires from the PCM.
The assembly consists of two major components:
• The internal mode switch that consists of:
- The housing (1), which makes up the stationary contacts.
- The insulator (2), which makes up the moving contacts and is secured on the detent lever (4).
• The lever assembly which consists of:
- The manual shaft (3)
- The detent lever (4)
The range detection is accomplished by securing the moving contacts to the detent lever. When the driver selects a PRNDL position, the detent lever inside the transmission rotates. This rotates the insulator which in turn grounds the four wires in a unique pattern for each gear selection, corresponding to the PRNDL position selected. The IMS is electrically connected by five wires (four of which the PCM supplies voltage to and one wire that is a common ground) to the transmission pass through connector.
Range Selector Displays Incorrect Range
The transmission internal mode switch (IMS) is a sliding contact switch attached to the selector detent inside the transmission side cover. The four inputs to the PCM indicate the position of the transmission range selector. The input voltage level at the PCM is high, B+, when the IMS is open and low when the switch is closed to ground. The four input parameters represented are Signals A, B, C and P, Parity. Refer to Transmission Internal Mode Switch Logic .
Go to Intermittent Conditions in Engine Controls - 3.4L
Go to Step 2
Select IMS A/B/C/P on the scan tool.
Does the IMS A/B/C/P display the specified values for each range?
Your best bet , take your vehicle to a qualified repair shop.
Jan 30, 2018 | 2003 Buick LeSabre
Su-c800u pre-amp switching not steady, keep darting from one mode to another and disrupting smooth flow of music
I had the same issue.the contacts on selector switch is dirty.All u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 14, 2012 | Technics Audio Players & Recorders
I have a 2004 Buick Regal LS. The transmission indicator in dash says its in Drive but the car is in Park and wont start. It started when I tried starting it after going to the store. At first the car...
It's probably a bad internal mode switch . The sensor is input to the PCM - engine computer .
Go to Powertrain Control Module Replacement in Engine Controls - 3.1L or Intermittent Conditions in Engine Controls - 3.8L
Go to Step 2
HI/HI/HI/HI
Go to Step 12
Go to Step 3
Your best bet , take it to a qualified repair shop !
May 12, 2017 | 2004 Buick Regal
MY DISTRABUTION DIAL FOR DEF.,VENT, ETC IS IN DEFROST AND WON'T CHANGE. THE DIAL TURNS BUT NOTHING CHANGES. I NEEN SOME ADVICE ON WHAT TO DO TO FIND PROBLEM AND FIX. THANKS GENO
Here is the info. I hope the pictures show up. please rate assistance. thx.
Air distribution within the vehicle is determined by the function selector switch position. Two airflow mode doors are used to direct airflow within the heater core and evaporator core housing. The function selector switch/cable assembly is used to position these airflow mode doors. Refer to Section 412-00 for description and operation of each of the system functions.
Function Selector Cable Assembly
The function selector cable assembly moves the airflow mode doors to the desired position using a 2-sided pull-pull type cable assembly. The function selector controls the cable movement. The end of the cable assembly attaches to the airflow mode door/temperature blend door actuating assembly which transfers the cable movement to the 2 airflow mode doors.
An electrical switch is incorporated into the function selector to notify the A/C switch assembly if DEFROST or FLOOR/DEFROST is selected. When DEFROST or FLOOR/DEFROST is selected, the A/C switch assembly will disable the RECIRC request button and send an A/C request to the powertrain control module (PCM) regardless of the A/C request button indicator ON/OFF status.
SECTION 412-01: Climate Control 2005 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/25/2004
Function Selector Switch adobe.gif Printable View (173 KB) Removal and Installation
  1. Remove the 4 bolts and position aside the lower steering column cover.
  1. Remove the function selector knob.
  1. Remove the center instrument panel finish panel.
    • Disconnect the cigar lighter electrical connector.
  1. Detach the function selector switch.
    1. Disconnect the electrical connector.
    1. Remove the screw and detach the function selector switch.
  1. Detach the function selector cable and remove the function selector switch/cable assembly.
  1. To install, reverse the removal procedure.
Aug 04, 2011 | 2005 Ford Focus
Only about half the modes work on mode selector dial
Sounds to me like the internal contacts aren't working correctly. Let your local camera store take a look. Hope it's under warranty.
Dec 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
128 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
