Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
Akai MPC 400 Plus Drive Crash
My internal 80gig drive has crashed (i think). The MPC won't let it boot up, keeps looking for the autoload fie, but eventually boots up. When you look for the disk it see's an EMPTY hard drive but you can't access it, personally I think it's failed to mount. What would the sollution be for this?
HEELP!!!
TIA.. ;)
  • 1 more comment
  • APKO Mar 04, 2008
    it's not a pc, it's an AKAI MPC4000 PLUS
  • APKO Mar 05, 2008
    YOU'RE REPLY WAS WRONG !!!!
    I AM NOT TALKING ABOUT YOUR AVERAGE CRAP OFF THE SHELF DELL PC, I'M ON ABOUT A PRO PIECE OF KIT USED IN MUSIC PRODUCTION NOT A HOME PC.
    I think you didn't even read the original posting correctly.
  • marz87 Sep 14, 2008
    1. i know the solution, but how would u transfer files if u can't use aksys?? is there a way you can save files and salvage the files in the hard drive?? and how would u open the mpc properly, any help would be great! i'm dying over here! thanks!!
I NEED AKAI DRUM MACHIN 4000. HOW TO FINDE IT
Posted on Feb 24, 2011
You need to buy a replacement drive on ebay or fro seagate.com
and if you can try to access your mpc4000 hd with your pc using akaisys...and if you can access the information, then store it on your desktop and when you replace the drive just load all of your info back on to the new drive..dont worry about the o.s. because its still on your mpc..so when you install the new drive and dump the sounds back on it..then your'e as good as new....i just finished the process on mine myself..hope it works out for ya..if not email me back @ sdr_recordz_ca@yahoo.com
Posted on Mar 15, 2008
  • 75 Answers
U go to dos mode to using boot disk or ,press F8 after post screen,then select dos mode and type in dos mode as 'chkdsk'
follow onscreen instruction ,thats all ,thats ok ,restart the pc then try again ,thats working i hope
regards
prasanna
Posted on Mar 04, 2008
How to get a micro solutins 80gig portable lockbox that ran on xp but the software disk crashed win7, not sure where to get or if there is software for windows7?
Download the Windows 7 version of the driver / app from the website of Micro Solutions, or there :
http://nathandrivers.com/download-driver/MICRO%20SOLUTIONS/LOCKBOX-FINGERPRINT-ACCESS-HARD-DRIVE-501001-80-GB
Aug 29, 2014 | Computers & Internet
Dban problem ( crash : "dev/sda" )
Use fdisk and / or format from command prompt. Easy and no fuss. gl
Nov 03, 2012 | Computers & Internet
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
I can't hear any sounds in my mpc 4000
Have you loaded sounds for the pads from an internal or external storage device? (Such as CD or Internal Hard Drive, if installed) - each time you turn on the power, the programs are cleared so the pads will not make any noise until you load the sounds you want.
Otherwise, it could be related to your speaker setup?
Provide some details on your system setup and whether you are loading programs etc.
Nov 07, 2010 | Akai MPC-4000 Plus Production Center (w/80...
My mpc 2000 wont load the boot disk when i insert it. it just says "insert mpc2000 disk!" what should i do?
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 21, 2010 | Akai MPC-4000 Plus Production Center (w/80...
I purchased an akai mpc 2500 used and it came with sounds and sequences all ready occupied, how do I delete all these sounds, or restore its factorys settings?
Try holding erase while you turn it on. You may have to turn off autoload also. You'll have to read the manual first ( pages 110 and 114 especially ) available here:http://www.mpcsounds.com/download_akai_mpc_manual.php It depends I think on whether the previous user saved to memory card or the internal HD.
Aug 20, 2010 | Akai Mpc2500 Music Production Center
Hard drive crashed installed new drive but have no drivers to boot the operating system,
plaese check motherboard setting and then boot setting check ....set the booting order is as
1st hard drive
2nd cdrom
3rd other etc.
then save this setting and reboot....
try it i think it is solved.if still unsolved then check the plug hard drive.
Aug 22, 2009 | Acer Aspire 5315 Notebook
Not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Mar 20, 2009 | Music
Hdd crash?
if it still detectable then there's some possibilities you might revived your hard drive, but if you already hear some clicking sounds on your drive, the drive is broken
Jan 09, 2009 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
Computers & Internet Logo
542 people viewed this question
Top Akai Computers & Internet Experts
Alun Cox
Michael Vincent Cruz
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
