Question about EliteGroup P4VMM2 Motherboard
Can I use DDR2 with my motherboard
Can I uses DDR2 in my P4Vmm2
    Master:
  • 351 Answers
Dear 10887,
Sorry you can not use DDR-2 in this motherboard. It support only DDR-1 RAM only.
Takecare
Posted on Mar 04, 2008
Elitegroup mainboard p4vmm2 user manual Need to know panel 2 pin configuration for front panel connectors.
Are you use p4vmm2 (v1.1a) motherboard?
Download p4vmm2(v1.1a) manual guide to solve your problems,
==>> (CLICK HERE) <<==
hopefully this are can help
thanks....
Jul 24, 2010 | EliteGroup P4VMM2 Motherboard
Will a Geforce4 MX4000 64 mb, DDR video card go into a Dell Dimension E521 with DDR2 and work ok.
  • 256MB PCI ExpressTM NVIDIA® GeForce® 7300LE TurboCache
  • 256MB ATI X1300 Pro
  • Integrated NVIDIA GeForce 6150 LE graphic GPU
  • spec for the E521, but the card is an older model, according to GeForce it will accept up to Windows XP
    Nov 09, 2009 | EliteGroup P4VMM2 Motherboard
    My P4vmm2 mobo burned my 512mb graphics card
    I don't think its a matter of your motherboard or what graphics card you put in it in this instance. It seems as though you have a bad power supply. If your power supply is bad then it will fry your motherboard with too much voltage and cook your processor also. I believe that is the reason your motherboard fried and it's almost a guarantee.
    *only do If all else fails and you have opened a computer up before*-I would suggest looking at the power supply and unscrewing it from the screws holding it to the case from the back and taking it out and looking at it. Just make sure you write down what connectors go to what parts on the motherboard and you will be fine. If you can do that also right down the serial number and brand name and buy a power supply of similar value and same name and rating and replace it and you should be problem free.
    Jun 09, 2009 | EliteGroup P4VMM2 Motherboard
    Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card? -jayvee_yao@yahoo.com
    Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
    best regards
    Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
    Memory
    hi im josh in cebu phils. friend may i help you? Friend sad to say that this motherboard doesn't support DDR2 on DDR and SDR. you can verify its support at www.dooyoo.co.uk. thats all my friend the answer is NO you can't use DDR2. good luck
    Feb 24, 2009 | EliteGroup P4VMM2 Motherboard
    Ddr not detected
    if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
    then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
    Feb 09, 2009 | EliteGroup P4VMM2 Motherboard
    Memory Upgrade - from 256DDR1 to 1GB DDR1
    sysa007,
    EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
    (If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
    http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
    The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
    Example PC2100 266MHz. OR PC1600 266MHz.
    Continuous beeping means the memory is not seated correctly.
    When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
    http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
    Good luck sysa007!
    More question, post here.
    Thank you for using fixya.
    If you find this helpful, please vote.
    Mike
    Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
    Motherboard and CPU
    Well anything along the 2ghz line in cpu will do and as long as you get a compitibale motherboard that will be fine. If you want a specific combination the intel BX80557E2220 processor (Core 2 Duo) ans the MSI P31 Neo-F LGA775 Intel P31 1333 FSB DDR2 ATX i personally think is great. Please bear in mind you may also need new RAM for this combi.
    Jun 21, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
    Upgrading VIDEO CARD
    If your motherboard's graphics slot is AGP and your graphics card is AGP then it should be fine if your motherboard is PCI-E and graphics is PCI-E it also is fine make sure your motherboard and graphics are compatible.
    May 29, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
    EliteGroup P4VMM2 Motherboard Logo
    Top EliteGroup Computers & Internet Experts
    David
    David
    Alun Cox
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
