Question about T-Mobile Wing™ Smartphone
Face plate how can i change my htc wing face plate?
  • 1 more comment
  • mzjayhawk Apr 28, 2008
    how do u change the faceplate
  • Anonymous Dec 19, 2008
    how do you change the faceplate out on the wing?
  • nessa13 Feb 08, 2009
    I need to change the faceplate of my wing..
Can i bypass align screen on a t-mobile wing? how
Posted on Mar 22, 2008
2002 Honda GL 1800 Gold Wing change license plate light
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
06 Wing Replace License Plate bulb with LED GL1800 Information Questions...
License plate light 1800 2012
Honda GL1800 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda GOLDWING GL1800 Owner Manual
Aug 31, 2012 | 2002 Honda GL 1800 Gold Wing
Unable to read disc
If your console is unable to read disc, then there seem to be a problem with the console, and the problem most likely is as a result of a bad laser/lens inside the console.
To replace the lens of the nitendo wii console, remove the two flip up panela on the side of the wii to reveal the black face plate with the controller ports and memory card slot.
Then remove the three screws located underneath the flip up panels using the fine phillips head screwdriver, then remove the black face plate.
Then remove the two tri wing screws located underneath the face plate. There are also two phillip head screws under the face plate but you can leave them in place.
Use a scalpel to peel off the two white stickers that are covering the screws located near the two front rubber feet on the bottom of the wii. This will reveal two black tri wing screws.
Use the scalpel to remove the two back ribber feet on the bottom of the wii, this will reveal two silver tri wing screws. Remove the two black tri wing screws and the two silver tri wing screws revealed on the bottom of the wii.
Use the scalpel to remove the rubber foot that is covering a screw in the top left corner at the back of the wii. Remove the screw using the fine phillip head screwdriver. Then use the scalpel to remove the white sticker covering the screw directly below the bar code on the back of the wii. Remove the screw with the tri wings screwdriver. Then use the fine phillip head screwdriver to remove the screw that is holding the battery cover in place on the back of the wii. This will reveal another screw that you can remove with the tri wing screwdriver.
Remove the front face plate of the wii, be careful because it is still attached to the console by a black and red wire. Disconnect the wires by lightly pulling on it. Remove the wii shell casing by gently lifting the separating it from the internal electronics of the console.
Remove the DVD drive by taking out the four corner screws using the large phillip head screwdriver then lift up the DVD drive and disconnect both power cable and ribbon cabble connecting it to the console.
Turn the disassembled console upside down, remove the two screws holding the DVD citcuit board in place, disconnect the three ribbon cable that are attached to the DVD circuit board, Use the tweezers to free the wires that are still connected to the circuit board from the plastic clips, Lift up the DVD circuit board and remove it from the way, then remove the lens case that is holding the lens ribbon cable in place.
Use the tweezers to remove the lens casing by lifting up on one side hooks that are holding it in place. This will reveal the laser lens unit, Which is held in place by two metal bars. Take out one of the metal bars by first removing the screws located next to it, and then gently lifting up on the plastic tab so you can slide it out.
Remove the laser lens unit and turn it over to reveal a white plastic part held in by a screw. Take out the screw so you can remove the white plastic part. You will need the part to install the replacement lens.
Attach the white plastic part from your old lens to your new lens using the same screw from the old unit. Place the new lens in the console and reassemble The DVD circuit board.
Remove the two solder points located on the lens ribbon by using a hot soldering iron.
Then reverse the process to reassemble the console.
Take care and good luck.
Hope this was helpful
Dec 03, 2010 | Nintendo Wii Console
Wing mirror bulb change (55 plate)
how do i change a bulb in near side wing mirror
Feb 07, 2010 | 2001 Mercedes-Benz C-Class
T-mobile wing - will they work together ideally
Yes, it does, for calls, phonebook, and data. I just upgraded from the tmobile Wing to the tmobile Touch Pro 2 which does not work for data on the tom tom 930T. If you have a problem still try the Xda-developers site look in the HTC Herald forum that is the HTC name for the Wing same phone... and get a custom rom for your phone.
May 03, 2009 | GPS
I CAN'T SEE VIDEO FROM WEBSITES?
go htc.america.com and dowload video stream for wing software after that you can play you tube and other real time tv service...
Jan 31, 2008 | T-Mobile Wing™ Smartphone
T-Mobile Wing LCD replacement
You may want to check with HTC website they make the wing.
Dec 29, 2007 | T-Mobile Wing™ Smartphone
Faceplate keypad
I would recommend for you to bring it to the t-mobile store before any more damaged. Good luck to you..
Dec 08, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
54 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
