Question about Kenwood KDC-MP2035 CD Player
Aux problem Hi I am having a problem with my auxiliary connection. When I first bought this and had it installed it worked fine, but one day it just stopped showing Aux when I would press the source button. Please help I am dieing to listen to my ipod!!! Thanks
  • Anonymous Jul 29, 2008
    como activo el aux
It has nothing to do with the input...just press src until you get to standby then hold menu until the menu is displayed. toggle down to aux then toggle right to turn it on...hit menu to save and youre all set, the aux will appear when go through the source menu.
Posted on Jul 17, 2008
  • 40 Answers
Gramizzle- the uint is not showiing that your plugged in,your input plug may be broke away from the pc board assy,or the inter connect cable may be damaged. Does the unit plug into the front of the of the unit,if so thats most likely where the problem is.This will need to be solldered up , I hope this helps. cooltek Mar03/08
Posted on Mar 04, 2008
Problem with Auxiliary 4-pin pow er connector
Can you provide any specifics on the make, model, and what the power connector is labeled on the motherboard? We'll also need the make/model of power supply and the labeling on the physical connector that your using from the power supply (i.e. PCIe, or ATX, etc.)
Sep 12, 2014 | Computers & Internet
Wire diagram
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Ducati despair not for a mere $10 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day. How to Tips for installing auxiliary lights on your motorcycle
Wiring in aux driving lights LED
DOWNLOAD 2013 Ducati Multistrada 1200 Granturismo
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 17, 2014 | 2013 Ducati Multistrada 1200 S Granturismo
I am connecting my phone through auxiliary cable but it is not working
Try using a different audio auxiliary cable. Not all brand cables are compatible with the Apple products. I have an audio cable that works fine with my daughters iPhone but when connected to my HTC the head unit in my car won't recognize that anything is even connected. So try using a different device with that cord or try using a different audio cord all together. It could also be in the settings for your iPods audio output.
Jan 09, 2014 | Sony XPLOD CDX-GT200 CD Player
I bought Philips auxiliary speakers for my Samsung monitor (used with HP desktop computer) which has no speakers. They worked fine until I moved...upon hooking them up in my new location...I do not have...
Hi, I think you connected it wrong. Make sure it is in the green plug on the back of the PC. If that does not fix it. You may need a new audio card. Good luck.
Aug 03, 2011 | Philips Audio Players & Recorders
When I turn the heat on the drivers side only kicks out cold air while the passenger side kicks out hot air...
The blend door is not working right or the in car air temperature sensor is faulty.
Removal & Installation Air Inlet Door Vacuum Motor To Remove:
  1. Remove the instrument panel.
  2. Remove the air inlet door motor mounting screws. CAUTION
    Do not attempt to bend any part of the air inlet duct door lever.
  3. Rotate and remove the air inlet door vacuum control motor.
To Install:
  1. Rotate and install the air inlet door vacuum control motor.
  2. Install and tighten the mounting screws.
  3. Install the instrument panel.
Defroster Door Vacuum Motor To Remove:
  1. Remove the passenger air bag module from the instrument panel.
  2. Disconnect the vacuum line and remove the mounting screws. CAUTION
    Do not attempt to bend any part of the defroster airflow mode door lever.
  3. Rotate and remove the vacuum control motor from the defrost door lever.
To Install:
  1. Rotate and install the vacuum control motor on the defrost door lever.
  3. Connect the vacuum line to the vacuum control motor.
  4. Install the passenger's air bag module.
Floor Console Register Duct Vacuum Motor To Remove:
  1. Remove the floor console.
  2. Remove the right-side instrument panel insulator.
  3. Working from the passenger's footwell, disconnect the vacuum hose.
  4. Remove the screws and the floor console register duct vacuum control motor. CAUTION
    Do not attempt to bend any part of the floor console register duct door lever.
  5. Rotate and remove the vacuum control motor from the floor console register duct door.
To Install:
  1. Rotate and install the vacuum control motor on the floor console register duct door.
  3. Connect the vacuum hose to the floor console register duct vacuum control motor.
  4. Install the insulator under the dash.
  5. Install the floor console.
Panel/Floor Door Vacuum Motor To Remove:
  1. Working through the driver footwell, remove the two screws and the shield. CAUTION
    Do not attempt to bend any part of the airflow mode door lever.
  2. Label and disconnect the two vacuum hoses.
  3. Remove the mounting screw.
  4. Lift, rotate and remove the panel/floor door vacuum control motor from the door lever.
To Install:
  1. Install the panel/floor door vacuum control motor on the door lever.
  2. Install and tighten the mounting screw.
  3. Connect the vacuum hoses in their original positions.
  4. Install the shield on the vacuum motor.
Auxiliary Air Distribution Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel access panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Remove the auxiliary air distribution blend door actuator screws.
  3. Disconnect the auxiliary air distribution blend door actuator connector.
To Install:
  1. Connect the auxiliary air distribution blend door actuator connector.
  2. Install the auxiliary air distribution blend door actuator screws.
  3. Install the right rear quarter trim panel access panel.
Auxiliary Temperature Blend Door Actuator To Remove:
  1. Remove the right rear quarter trim panel. Auxiliary climate control housing removal and installation ford-10-00-4589.gif
  2. Disconnect the temperature auxiliary temperature blend door actuator connector.
  3. Remove the temperature auxiliary temperature blend door actuator screws.
  4. Remove the temperature auxiliary temperature blend door actuator.
To Install:
  1. Install the temperature auxiliary temperature blend door actuator.
  2. Install the temperature auxiliary temperature blend door actuator screws.
  3. Connect the temperature auxiliary temperature blend door actuator connector.
  4. Install the right rear quarter trim panel.
--- In-Car Temperature Sensor Removal & Installation To Remove:
  1. Remove the instrument cluster finish panel.
  2. Disconnect the in-vehicle temperature sensor connector.
  3. Disconnect the in-vehicle temperature sensor aspirator tube.
  4. Remove the in-vehicle temperature sensor screws.
  5. Remove the in-vehicle temperature sensor.
To Install:
  1. Install the in-vehicle temperature sensor.
  2. Install the in-vehicle temperature sensor screws.
  3. Connect the in-vehicle temperature sensor aspirator tube.
  4. Connect the in-vehicle temperature sensor connector.
  5. Install the instrument cluster finish panel.
Oct 07, 2010 | 2004 Ford Freestar
White lines appearing on the screen also FIFA 09 problem
i dont care and stop asking ps3s are crashing and call sony no one here can fix these problem so save urself time and call sony
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
Switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Nov 12, 2007 | Kenwood eXcelon KDC-X579 CD Player
Kenwood KDC-MP2035 CD Player Logo
184 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
