Question about Samsung Dell Latitude D600 14.1 LCD SXGA+ Display - LTN141P4-L01 (LTN141P4L01) CD-ROM Drive
Dell d600 lcd problems
Lcd comes on initially and then shuts down. External monitor works fine. I bought a used LCD and same thing. I bought from someone reputable. Any ideas?
Thanks,
Bret Nashville, TN
The power inverter for the lcd backlight could be bad.
Posted on Mar 11, 2008
I have Dell latitude d630, It is switching on but no display, when I switch on my laptop, its num lock light is on. capslock light works when i use caps button. Power light is on but hard drive light...
Attach an external monitor. Does the external come on? May have to use the FN key + F8 to toggle it between the LCD and the attached monitor.
When you say that the laptop LCD glows a little bit, this makes me think the back light of the LCD has gone bad. If it displays fine on the external, then it is a pretty good chance the LCD back light has failed. If you can attach an external monitor and see something on it, run the built hardware test. This is done from a powered down state. Then press the FN key + Power, this places it into the diagnostic. Follow the on screen instructions. If it comes back with an error code, write this down and compare it to this list at Dell website. http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=14B3819735D6B40EE0401E0A55177ED2
Occasionally, reseating the LCD video cable to the mother board will have a positive effect. Here is a link to the online service manual that explains how to reset it. In the diagram it is labeled #5 It is located under the keyboard.
Aug 10, 2010 | Dell Latitude D630 Notebook
LCD blinks once but then goes off, external monitor works fine
Most likely it is the inverter not getting sufficent power. Either it has gone bad or some cable is dead.
Aug 19, 2009 | Dell InspironTM 1501 Notebook
I have a latitude D600 notebook, and connected 1905fp lcd monitor it has been working for few years without problems. Now lcd displays information for 2 seconds and the screen goes blank. I know the LCD is...
please try it without the lcd i mean use your note book without the external lcd, am sure your system has a processor and or processor fan problems try lose the computer and blow it, i mean the cooling fan of the processor, if no avail, then you will need a new motherboard for your system, but am pretty sure its the processor that is fulty, thanlks
Jul 17, 2009 | Dell UltraSharp 1905FP LCD Monitor
How to output the monitor.
Fn + F8 will toggle the VGA port on the back if the System, Press a 2nd time, External and LCD, press again, LCD only again. (Wait about 15 to 20 seconds for the external port to initialize after pressing Fn+F8 as it has to detect the projector)
Apr 04, 2009 | Dell Latitude D600 Notebook
Lcd inverter--need to replace
They aren't hard to replace. If you can find one on eBay, get it and use the on-line manuals from Dell's web site. They are very clear and easy to follow.
Dec 24, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Monitor
Can you connect external monitor?
check if it works fine with external monitor.,...
Sep 04, 2008 | Dell Latitude D600 Notebook
DEll Latitude D600
The back lighting for the LCD panel has gone out. The picture is there, you just can't see it without the backlighting. So, it could be the Inverter that supplies power to the back lights or it could be the CCFT lamps that burned out. In either case your local computer repair shop should be able to fix it. If it is still under warranty take it back to where you bought it and they should have it repaired under warranty.
Aug 04, 2008 | Dell Latitude D600 Notebook
Latitude D600 LCD/VIDEO Problem
Sorry to be the one to tell you what you already know. You do have an LCD problem as you suspected. Hooking to an external monitor pretty much ruled out anything else. The good news is that there are a bazillion lattitudes out there, some do not work so, a cheap Lcd should be easy to come by. Technicaly it is not hard to swap LCD. Acquire replacement LCD and cerefully install it. OR troubleshoot existing LCD to component level and repair the defect. Or get a new laptop..
Jan 19, 2008 | Dell Latitude D600 Notebook
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Computers & Internet Logo
228 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
