Question about EMC 1U UPS 120V FOR AX150 (AX150UPS120V) UPS System
Can emc ax150 work without the UPS cable?
Can the emc ax150 work without the UPS cable?
  • 2 more comments
  • Amy L Moore Jan 10, 2012
    Bob,
    Would you mind sending me a copy of the executable? almoore@mt.gov
    Thanks!
  • Kevin Feb 13, 2012
    Could you please send me the executable at kme19@yahoo.com.
    Thank you.
  • maxovride
    maxovride Feb 14, 2012
    Anyone have the exe file or source for this? I inherited a AX150 at work and the ups is no longer around. Our whole building on on battery backup and Generator backup so it would take pretty major outage for us to have an issue. But if anyone could send me the EXE or the source that would be awesome. Please send to (jon dot slaterhouse at gmail dot com)
  • maxovride
    maxovride Feb 20, 2012
    For anyone that is still looking for a program to Emulate the APC SmartUPS for the AX150. Here is a link to one that is done in C#. You will need .Net installed on you system to run this (4.0 it may work with 3.5). I have it running on my system right now and it has allowed for Write Caching to be enabled without the UPS. The program is based on Serial Comm program found here http://www.dreamincode.net/forums/topic/...
    The program i am using can be found @http://slaterhouse.com/AX150_APC.zip
    I will be making some changes to it as the program right now has alot more to it then needed, but for right now it does work. (do not use the HEX option as it has not been finished.)
    If you would like the source for this let me know.
I moved my AX-150 to a location that would not allow me to install the UPS as it has redundant power/UPS and you should not connect a UPS to the output of another UPS.
Without the UPS the AX-150 forces the Write Cache to be Disabled. Performance drops, form what I have tested, to around 25x slower. This is due to not just turning off the controllers write cache, but as with ALL RAID controllers, the onboard drive 8/16M write cache is disabled as well so the drives are even slower then they would be if they where not used on a RAID controller.
The write cache disable is your real killer! Actually the write cache is disabled one a week while the REQUIRED battery test is performed.
My solution was to write an APC SmartUPS Serial Emulator that talks to the AX-150 telling it that the UPS is working fine so the write cache never gets turned off, including during the weekly battery test!
Here is the needed RJ45 to DB9F. Colors are base on someone cutting off the end of a cat5 patch cable.
You can find the APC SmartUPS commands off the web.
Communications capture:
Normal Comms from/to AX-150
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
!!! Weekly Batt Test Time !!!!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
W >> !! Tests battery, like pushing the test button on the front panel
OK<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
X >> !! Self-test results
OK<0D><0A>
l >> !! Low transfer voltage
097<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
n >> !! Get Serial number
AS0632112344<00><0D><0A>
R >>
BYE<0D><0A>
!!! End of Test !!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
I would be happy to share the Delphi source and EXE with anyone that would like to use it. Do not see a place to attach files here.
Can give you snapshot of main command-response logic:
if Result = pmerGood then
begin
tRx := Engine.RxString;
if cbHex.Checked then
Msg(Engine.SeeBytes(tRx)+ ' >> ' + #$0D + #$0A)
else
Msg(Engine.SeeChars(tRx)+ ' >> ' + #$0D + #$0A);
PendingCmd := '';
Engine.CharDelay := 0;
CmdData := 'NA' + #$0D + #$0A;
if length(tRx) > 0 then
case ord(tRx[1]) of
$01 : CmdData := 'Smart-UPS 750 RM' + #$0D + #$0A;
$1A : CmdData := '#uD43127130133136uA43108110112114uI43253257261265uM432252292' + '33237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e47200153045607590oD13120oA13100oI33230240220oM13208s431HMLq4820205081114172023p483090180270360450540630000k4310TNr483000060120180240300360420E443336168ON OFF' + #$0D + #$0A;
ord('A') : CmdData := 'OK' + #$0D + #$0A;
ord('B') : CmdData := '27.40' + #$0D + #$0A;
ord('C') : CmdData := '016.2' + #$0D + #$0A;
ord('D') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('E') : CmdData := '336' + #$0D + #$0A;
ord('F') : CmdData := '60.00' + #$0D + #$0A;
ord('G') : CmdData := 'S' + #$0D + #$0A;
ord('I') : CmdData := 'FF' + #$0D + #$0A;
ord('J') : CmdData := '0F,00' + #$0D + #$0A;
ord('K') : CmdData := 'OK' + #$0D + #$0A;
ord('L') : CmdData := '126.7' + #$0D + #$0A;
ord('M') : CmdData := '128.1' + #$0D + #$0A;
ord('N') : CmdData := '125.2' + #$0D + #$0A;
ord('O') : CmdData := '113.0' + #$0D + #$0A;
ord('P') : CmdData := '000.0' + #$0D + #$0A;
ord('Q') : CmdData := '08' + #$0D + #$0A;
ord('R') : CmdData := 'BYE' + #$0D + #$0A;
ord('S') : CmdData := 'OK' + #$0D + #$0A;
ord('U') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('V') : CmdData := 'FWD' + #$0D + #$0A;
ord('W') : CmdData := 'OK' + #$0D + #$0A;
ord('X') : CmdData := 'OK' + #$0D + #$0A;
ord('Y') : CmdData := 'SM' + #$0D + #$0A;
ord('a') : CmdData := '3.!$%+?=#|.' + #$01 + #$0E + #$1A + ''')+-89>@ABCDEFGKLMNOPQRSUVWXYZabcefgjklmnopqrsuxyz~' + #$0D + #$0A;
ord('b') : CmdData := '615.3.D' + #$0D + #$0A;
ord('c') : CmdData := 'UPS_IDEN' + #$0D + #$0A;
ord('e') : CmdData := '00' + #$0D + #$0A;
ord('g') : CmdData := '024' + #$0D + #$0A;
ord('f') : CmdData := '100.0' + #$0D + #$0A;
ord('i') : CmdData := 'FWD' + #$0D + #$0A;
ord('j') : CmdData := '0375:' + #$0D + #$0A;
ord('k') : CmdData := '0' + #$0D + #$0A;
ord('l') : CmdData := '097' + #$0D + #$0A;
ord('m') : CmdData := '08/03/06' + #$0D + #$0A;
ord('n') : CmdData := 'AS0632112344' + #$00 + #$0D + #$0A;
ord('o') : CmdData := '120' + #$0D + #$0A;
ord('p') : CmdData := '090' + #$0D + #$0A;
ord('q') : CmdData := '02' + #$0D + #$0A;
ord('r') : CmdData := '000' + #$0D + #$0A;
ord('s') : CmdData := 'H' + #$0D + #$0A;
ord('u') : CmdData := '127' + #$0D + #$0A;
ord('x') : CmdData := '01/01/10' + #$0D + #$0A;
ord('y') : CmdData := '(C) APCC' + #$0D + #$0A;
ord('z') : CmdData := 'CLEAR' + #$0D + #$0A;
ord('9') : CmdData := 'FF' + #$0D + #$0A;
end;
if CmdData <> '' then
begin
Msg(Engine.SeeBytes(CmdData)+ #$0D + #$0A)
else
Msg(Engine.SeeChars(CmdData)+ #$0D + #$0A);
Engine.SendMsg := CmdData;
end;
Bob A. Hay
Posted on May 04, 2010
  • trails_235 Dec 13, 2010
    Bob, is there a place you could put the exe that I could grab a copy from?
  • McNulty45 Sep 02, 2011
    Bob, Great Article. We have had a hell of a time finding this same cable for the AX100 to an APC SMART UPS 750. Dell doesn't carry the cable anymore and APC doesn't have any knowledge of it. Checking with EMC next. Do you have the original cable wiring specs to include special resistor? Also can you send the source code and .exe to mcnulty45@gmail.com. Also what OS Platform will this program run on? Windows? RHEL?
    Thanks again!!
Can anyone with this cable confirm the pinout? I haven't had success with the pinout displayed above. I have an actual APC750, so I am not emulating the UPS. The pinout above that only uses 3 wires doesn't not get interpreted by the ax150i as being a valid APC750.
Any help is appreciated,
T
Posted on Aug 03, 2012
This looks like exactly what we are looking for! the wiring diagram looks a bit confusing though, especially when I look at a more indepth article, which gives a completely different wiring diagram http://blog.amal.net/?p=3154
Can anyone advise the correct cable pinout please?
Thanks
Posted on May 10, 2012
I'm also very interested in the exe, I can't find the cable anywhere
please send it to souhil@gmail.com
Posted on Oct 28, 2011
Can you make the exe available.
Cheers
Scott
Posted on Sep 26, 2011
  • 348 Answers
Yes it can work but just auto shutdown function will not work means it will not shutdown before empty battery
Posted on Mar 07, 2010
  • TIMMUR Oct 08, 2010
    Thanks for posting this. I am actually trying to recreate the cable and I think I have done it successfully but when i connect via hyper terminal at 2400bps all the SP throws is a "S" which means it trying to tell the UPS to do a soft shut down. The UPS never listens because this command is only valid when the UPS is running on battery. Do you know why the SP is sending an S and not the commands you defined above? I am really stumped, i tested all of the commands your app produces against my UPS and received the same results as your command responses. The SPA still shows the UPS Module as EMPTY but I have been able to create a cable that at least receives the UPS Commands.
    Any help you may be able to offer would appreciated because i have been able to find any help from EMC.
SOURCE:
Run ups without cooling fan
You give little information, can you tell us more?
If the UPS is in a sufficiently cold room it can last without a fan.
But better is if you use a UPS Line Interactive mode fashion.
It is quiet until it starts working.
May 10, 2014 | Computers & Internet
Had emc rebuilt, now wont start
Try a complete unit from scrappers complete with transponder and the chip from the key
Mar 22, 2013 | 1996 GMC Sierra
Console cable
Console cables are usually:
12345678
87654321
basically it's a straight thru but flipped over on one end.
Mar 10, 2010 | EMC CLARiiON AX150 (AXS207500KIT) Network...
How can i tell if files are actually backing up. I would like to know where to look for additional comfort that I am having back-ups made.
if you have a maintenance plan that is doing this for you automatically, then try and restore one of the backups to see if it is ok.
Oct 12, 2009 | Dantz EMC Retrospect SQL Server Agent 6.5...
How to configure AX 150
EMC offers a great documentation site.
Here is it:
http://www.emc.com/microsites/clariion-support/ax150/install.esp?redirect=true
You can select Install and you can create a great customizes doc for installation steps.
Generally you can configure AX150 from a web based interface.
Enter the ip addess of the storage processor and a java application will appears.
You should do the following:
1. Create raid groups
2. Create LUNs on raid group
3. Register the hosts
4. Add hosts and LUNs to a storage groups
Dec 17, 2008 | EMC CLARiiON AX150
How to reset dell AX150
This is a storage drive from dell.
Dell have quirky systems that are different to the normal run of the mill PC components.
I can only advise you to refer to Dell in this instance.
Sep 15, 2008 | Dell AX150 Single Processor Storage Array
Yamaha Not Working in France
Hmmmmm......In the repair shop, when they fire up the receiver, is it with or without speakers hooked up to it ?
If it fires up OK in the shop, and the speakers ARE attached,, that means that the amp will drive a load ( the speakers ).
At home, Try firing up the amp without speakers. If it fires up OK, then you have a speaker or cable problem. In that case, try using one speaker and one cable at a time. If the amp fires up, then that particular speaker and cable are OK. Mark them as OK and grab another speaker and cable and repeat until you find the culprit.
If the amp will not fire up without speakers ( at home ), then you must have some sort of wiring problem in your home.
I would not even consider buying a UPS until the wiring has been checked out by a qualified electrician. That way you don't have a blown up UPS too....
Good luck.....Rob
Mar 04, 2008 | Yamaha RX-V800 Receiver
Slow file transfer
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
Aug 15, 2007 | EMC CLARiiON AX150 (AXS207500KIT) Network...
Storage Processor A Problem
I'm not an EMC guy, but that error makes me question the connectivity of SP-A to your Management Server. Check the host port status on both controllers to see if they are active. If this is on a SAN, you might check the switch port status going to SP-A.
Aug 11, 2007 | EMC CLARiiON AX150
Computers & Internet Logo
2,419 people viewed this question
Top EMC Computers & Internet Experts
Alun Cox
k24674
Are you an EMC Computer and Internet Expert? Answer questions, earn points and help others
