Question about Dell Dimension 3000 PC Desktop
Trying to get cover off 3000 pc desktop
In order to remove the PC cover, the Dell manual mentions to slide the latch in the back and pull back to remove the cover. Easier said then done. The cover won't budge. When you lift the cover side with a butter knife (to have a look in) the cover looks like it is clipped in.. i'm so frusturated i fell liking taking a hammer to it,
  • Solara012001 Jan 21, 2009
    I've tried what he said. No Luck!! In the meantime, I am destroying the cover trying to get it off!!!! Someone Please help!!!
    Genius:
  • 1,226 Answers
Hello!
PLease look in the bottom of the cover there maybe locked clip that prevent the cover to open. you should push it to unlocked the cover and slide it.
melnavz
Posted on Mar 04, 2008
I can't get the outer shell off my dell dimension computer to access the hard drive. What am i missing?
Check out the manual here:
http://support.dell.com/support/edocs/systems/dim2400/en/F75560LRs.pdf
if that dont help try this:
Lay your computer on its side with the computer cover facing up.
6 If your computer cover has a cover latch, slide and hold the cover latch.
7 Grip the indents on the computer cover, and slide the computer cover toward the back of the
computer.
8 Place the computer cover on a level surface.
Jun 12, 2010 | Dell Dimension 2400 PC Desktop
Dimension 1100 PC Desktop: how to open the case...
  1. Follow the procedures in Before You Begin.
  2. Lay your computer on its side with the computer cover facing up.
  3. If your computer cover has a cover latch, slide and hold the cover latch.
  4. Grip the indents on the computer cover, and slide the computer cover toward the back of the computer.
May 18, 2010 | Dell Dimension 1100 PC Desktop
I cant find a way to open up the CPU case to fit a Wireless adapt
see the link for more info
http://support.dell.com/support/edocs/systems/dim3000/en/SM/cvrop.htm#wp1076111
Apr 06, 2010 | Dell Dimension 3000 PC Desktop
How to remove outside cover on dell dimension 3000 desktop pc. need to make mods
CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
How do I open the case to install new ram?
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/cvrop.htm#1138085
Steps from the manual:
  1. Follow the procedures in "Before You Begin."
Jan 03, 2010 | Dell Dimension 4600 PC Desktop
I am looking for a way to take off the side panel, as I am assuming this is where the new memory has to go on the dell dimension 3000 desktop
Unscrew 1-2 screws from the side panel.
Jul 09, 2009 | Dell Computers & Internet
How do I take the desktop apart to put in more
Computer off, cables unplugged. Lay the computer on it's right side. (As you view the computer from the front) On the back towards the bottom, you'll see a slide latch. Looks like a metal tab that sticks out a little. laying on the side, the latch is pushed down towards the bottom. Then you will see two indentations on the side cover. Looks like you would use your fingers to grab these indentations to pull on. You do.You are trying to slide the cover towards the back.I HAVE run into one, that the slide lock would not fully release all the way. Makes it REAL FUN(?) to get the side cover off. I had to use a very non-professional way to release the slide lock, and slide the side cover back. (A little case metal bending, was involved! Fortunately I'm a pro, and it was brought to me with this problem. I received permission to open it anyway I could. I bent everything back smooth, and removed this slide lock)This is Dell.com/Support, and the Manuals page for the Dell Dimension 4700. More specifically, the page that shows and tells you how to open the computer case.http://support.dell.com/support/edocs/systems/dim4700/sm/cvrop.htm#wp1052331After you view this, I also suggest you may want to take a look at the page for installing Ram Memory. Just go to the top of this page, and click on the blue -> Back to contents page <-
Jun 05, 2009 | Dell Dimension 4700 PC Desktop
How to open a dell b110 case
http://support.dell.com/support/edocs/systems/dim1100/en/SM/cvrop.htm#wp1076111
You can see how by folloing the link above!
And here is the manual if you need it
http://support.dell.com/support/edocs/systems/dimB110/index.htm
Good luck to you!
Please take a minute and vote
Nic
Jan 28, 2009 | Dell Dimension™ B110 PC Desktop
The Cover on my Dell Dimension 3000 will not come off. It seems to be stuck. It will release just a little and it will not slide off. I am destroying the cover. I tried what "teeters" suggested with no...
Pull the tab down on the back right (as you look at the back) and hold it down, slide the side towards the back and lift up... thats how your ment 2 get it open....
Let me know...
Matt
Jan 21, 2009 | Dell Dimension 3000 PC Desktop
Removing cover on gateway 300
This a tower right? I don't have a gateway but I have a dell and a compaq tower they come apart pretty much the same way. The left side panel slides out by pulling from the back. Some may have a screw or two you have to loosen or take out. Then you can either slide it by pulling from the back or there could be a latch that you slide to unlock it. Wow I can't believe it 60 bucks. Just keep messing with it you'll figure it out!
Oct 09, 2007 | Gateway 300 C PC Desktop
Dell Dimension 3000 PC Desktop Logo
286 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
