Mgnovox Projection tv
I have a wave on the bottom of my screen and everything is double What would cause this and how to fix it Thanks
  • Anonymous Nov 29, 2008
    wave at botton red conv. off
  • 61 Answers
Sounds like you have bad convergence amps,these ic's are on big heat sinks,with a number on the ic like this number,stk 392-110
Posted on Mar 04, 2008
TV HAS A RED WAVE ACROSS THE BOTTOM CAUSING DOUBLE VISION
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Panasonic PT-56TWD63 56 in. Rear...
Is like a wave at the bottom of the screen and in
Convergence failure. You can get the convergence repair kit for your model at www.tvrepairworld.com which contains the parts and the CD with repair instructions.
Jul 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
There is a wave/bow in the bottom and top of the picture on the screen of my Toshiba 70HX50. When I am in the grid screen in the service mode, it looks like the center is 'bowed' out. How do I adjust this...
Slight error in the alignment of a projection TV is pretty much normal. If the problem cannot be seen on a normal TV picture, I would not spend the money.
However, if the problem is severe and causes colour double images, it is convergence and will need parts replaced - about $200-$600 depending on service call, parts, labour, etc.
Minor adjustment takes a skilled technician. attempting it yourself will likely cause the set to stop functioning. (Digital adjustment is not forgiving)
Mar 30, 2010 | Toshiba 43H70 43" Rear Projection...
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double images
Convergence amps bad call a tech make sure he does'nt use generic parts A Toshiba service center should know what to do around 300.00
Apr 12, 2009 | Toshiba 50H82 50" Rear Projection...
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Screen appears curved on top and bottom
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 22, 2008 | Philips 55PW9363 55" Rear Projection...
Convergence Projection tv
Explain the wave. Do you mean your video is shrinking then expanding. If so www.magnavoxhelp.com has a kit that will fix this common problem.
Jul 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Waves
If they are green, red and blue lines, you have a typical convergence problem that happens in almost every rear tube projection set ever made. There are two IC's that need replacing to correct your problem. If you do not know how to solder, unsolder, work on solid state electronics, you really should call out an experienced tech to assist you in this repair. These sets now a days have no user replaceable parts inside of them. A TV set as this one, should not be a place to experiment around inside of. Good Luck
Oct 08, 2006 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
