Question about RCA OPAL M4001 MP3 Player
Charging player/downloading songs causes computer to crash.
I was trying to charge the mpo3 unit using the usb line and subminiture plug and within five minutes, my computer froze up. When I restarted the unit, my screen went blank. I took it to MicroCenter where I purchased it, and I was told that the I/O controller was fried. It there an alternative to charging the mp3 unit without plugging it into the computer's usb ports.
  • Anonymous Mar 04, 2008
    i have lyra rca m4001 mp3 can get it to charger with usb cable nothing happen can anyone help me out try everything.....
You can purchase a "AC to USB" power adapter for about $30
Posted on May 25, 2008
2 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: Charging RCA Opal M4001 player/downloading songs causes computer to crash
f14ad0c.gif45c6c12.jpg You get one to this site or may purchase in other outlet:
USB to AC Charger Adapter
Enjoy
Posted on Mar 04, 2008
Enjoy
Mar 04, 2008 | RCA OPAL M4001 MP3 Player
Is the usb chord the charger and what you use to download
Hi Cedric
Yes the chord is the charging cable and the download/upload cable.
You will plug it into the usb port on your computer for charging.
You will need Windows Media Player installed in your computer ...after it is installed add your songs to Windows Media Player, then plug your Mp3 player in with Windowns Media Player running, your mp3 player will be recognized and then you can add the songs you added to Windows Media Player.
Please take time to rate me
Bud
May 03, 2013 | Polaroid MP3 Player
I can see the songs on my computer that I have uploaded onto my SanDisk and I can also add new music as well, But the system will not charge and when I connect it to the USB cord it says connected but it...
ensure the unit is chargeable using usb data cable, usb charger has only 2 out of 4 wires connected to the charger whereas when the cable is used as data cable all the 4 wires are connected and the device acts as a usb device, this may block the charging of the device due to internal circuit design within the device.
Oct 08, 2009 | SanDisk Sansa Clip MP3 Player
Ipod won't work unless plugged in to computer or mains
alison65,
good day, the only possible cause why your player can only power up using it's own charger or through pc connection is:
1) The connection of the rechargeable battery inside the player is loose or out of contact
2) The rechargeable battery itself is faulty
3) The connection from the charging line is loose or out of contact
most likely your problem is within the internal of the unit.
cheers,
mark
Jan 29, 2009 | Apple iPod nano
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
CHARGING A 1 DAY USED SANDISK SANSA MP3 4G
Run the Sansa Recovery Tool from Sandisks' website and start over from scratch. Usually this problem is caused by trying to transfer too many songs at once, but any number of Rhapsody errors could have caused this.
-Tha Mp3 Doctor
Nov 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Device cannot start?...
1.Check usb adapter cable.
2.Check whether the Mp3 player hold button is pressed
3.Reconnect usb cable to other slot
4.Reset default settings on the mp3 player
5.control panel-system-device manager-hardware-USb serial controllers. when the mpo3 player is connected.it might offer a dedicated serial port for the device. check for properties
5.Check IIRQ settings conflicted with any other device
6.if all the settings is normal then the problem with flash Ram present inside the mp3 player. the USB serial controller might be damaged
Dec 20, 2007 | Philips GoGear SA178 MP3 Player
Charging problem....
You might have a "bad" song? Try wipping the songs off and resyncing youre player. Also, for the charging problem. Are you charging it through your computer? I've found that these players charge ALOT better through an AC outlet. I hope this helps.
Sep 05, 2007 | Philips SA920017 MP3 Player
Samsung mp3 player crash
Hi undercover. I don't have experience of your actual model, but I've had a similar thing happen to my Inovix MP3/4 player when it crashed (also crashing my whole computer!) and went completely 'dead'. Plugging it into the USB port had no effect - no charge symbol and the computer didn't even acknowledge something was being plugged in. Basically, I kept on trying every time I was on the computer! 2 days later, I plugged it in and 'ding-dong' Windows XP recognised something was in the USB port. I then carried out a Firmware re-load using the supplied disc, and my player burst into life! Firmware crashes are pretty common with various players, I believe. Depending on how old your player is, try the manufacturer's website to see if they've updated the Firmware. Good luck.
Aug 29, 2007 | Audio Players & Recorders
RCA OPAL M4001 MP3 Player Logo
60 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
