Question about Frigidaire GLEQ2152ES Electric Dryer
Dr code on dryer
I had the "cleab filter" problem where I tookt he adivce of another tech on this site to hold the select/ option button for x amount of time to reset the dryer. That worked, it did reset the clean filter code, however now it flashes 3 times and the code id "dr" for door, I have locked and unlocked the door, I still can't get the machine to reset the 'dr" code to allow the machine to start. Thank so much for anyones help
Maria
  • 3 more comments
  • rere29 Mar 04, 2008
    Where is the switch? It doesn't show on my manual. The correct model no# is : FEFB9200ESO. Sorry for the confusion.
    thanks
    maria
  • ssmpfi Sep 28, 2008
    i have same problem , code dr, i tested switch it is ok , i even by-passed switch , the dryer still says dr , im at wits end ,
  • Anonymous Jan 30, 2009
    The dryer does not produce any heat anymore. Is there a way that I can fix that without buying a new dryer??
  • robert samples May 11, 2010
    is that your right model number
  • Gary Davd
    Gary Davd May 11, 2010
    need to check the switch in the door lock assby
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
SOURCE: Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Posted on Feb 10, 2008
nick_helpap
  • 334 Answers
SOURCE: Clean Lint Filter Light Keeps Dryer from starting
have u tryed to unplug the dryer 10 min reset breaker then plug back in thx nick
Posted on Oct 06, 2008
no85
  • 4 Answers
SOURCE: 3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Posted on Mar 20, 2009
buffalonyman
  • 1865 Answers
SOURCE: code dr keeps popping up even if the door is shut and the dryer will not turn on
It means that the door switch is making a bad connection. You should look around near the door switch for loose parts or wires. If everything seems tight, perhaps replace the door switch
Posted on May 06, 2009
I am trying to use the dryer and an error code of LOC comes on and it won't run
The control is locked. Press and hold the OPTIONS and SELECT button at the same time for 10 seconds or until "LOC" turns off. To lock the control, press and hold OPTIONS and SELECT until "LOC" is displayed. Unplug the machine for at least 30 minutes if pressing and holding the said buttons does not unlock the control to eliminate the possibility of an electronic glitch. The control may need to be replaced if unplugging the dryer still doesn't solve the problem.
Dec 31, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Super...
Where is the resset buton on frigidaire electric dryer machine?
  1. Press and hold the "Control Lock" button for five seconds to lock the dryer. Release the button when the dryer beeps, indicating that the dryer is in locked position.
  2. Press and hold the "Control Lock" button for five seconds to release the lock.
  3. Press and hold the "Options" and "Select" buttons at the same time on Frigidaire dryer models that do not have a "Control Lock" button. Hold the buttons for 10 seconds until "LOC" is displayed.
  4. Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.
  5. please comment on these by telling how helpful.
Dec 20, 2010 | Frigidaire Electric Dryer
Frigidaire affinity dryer will not start. It gets the dr code. I assume that means door problem but if I hold the select button down on the temperature selection it will run but as soon as i let go it...
repairs should be performed by an authorized servicer. insure that the door is properly closed unplug the unit and perform a continuity check on the door switch. if the door switch is ok reconnect the door switch and plug the unit to the power supply. if the problem still exists then you have a control issue. be sure to call your nearest service center to schedule for a repair. have your model and serial number available.
Sep 23, 2017 | Frigidaire Dryers
Err68
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Jan 01, 2009 | Dryers
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Error code DR
A copy:
jeff.
__________________
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
76 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
